Is this an actual method for completely draining coolant/water from the block?
Old Sep 30, 2018 | 01:24 AM
00-Z28's Avatar
Default Is this an actual method for completely draining coolant/water from the block?
I'm about to flush my coolant and was looking for ways to completely empty the block of the hose water I'll be using during the flush. Of course there's the block drain plugs which are a pain in the *** to get to, but someone mentioned the following method which sounds kind of scary to me but would definitely be a hell of a lot easier. They said to have the engine running with the hose running water through the top while it drains underneath (I'm assuming through the radiator drain with the petcock removed?), when the system is clean they said to turn off the hose and continue to let the water drain while leaving the engine running for a short time to allow all the water to drain from the block. It doesn't sound too safe so I was wondering if this is really something that people do with success? It doesn't damage anything like the water pump or engine? If not, what would be the recommended amount of time to let it drain once the hose has been turned off?
I forgot to mention that the thermostat would already be out of the car during all this.
Old Sep 30, 2018 | 07:19 AM
RB04Av's Avatar
That will not "drain" the block. It will "flush" it, to the extent that it will circulate some water through it and somewhat push out the A/F mixture (or whatever else is in it) but the last half-gallon or so will remain trapped in the block on each side, as well as whatever residue is settled down at the bottom.
Best to do it right: pull the drain plugs and let it all out.
Old Sep 30, 2018 | 12:21 PM
00-Z28's Avatar
I appreciate the clarification! After the flush, the last half gallon trapped in the block should be just water from the flush, right? Along with maybe some residue? I'm really trying to avoid messing with those block drain plugs, so I'll likely flush the system, fill it completely with distilled water and run it for a bit, drain that then put the t-stat back on and add about 5-6 quarts coolant (I live in the northeast) + some more distilled water. I'm thinking that should take a good portion of the hose water out, right?
So running the engine while draining the hose water should remove at least some of what's in the block as opposed to draining it with the engine turned off?
If so, does anyone know at what point I can safely run the engine during the flush while the water is draining?
Sorry for all the questions, I've never done it on this car before.
Old Sep 30, 2018 | 01:57 PM
RB04Av's Avatar
You can run the engine anytime, just don't burn it up.
You'd be much better off to take out the drain plugs. Just buck up and do it.
Old Sep 30, 2018 | 03:26 PM
s30.hybrid's Avatar
Y’all new schoolers don’t know how good you got it LOL. Try doing this on an old school SBC with freeze plugs in the block. Removing the block plugs now a days is a breeze compared to the old stuff.
J/k, well sort of...
Old Sep 30, 2018 | 03:42 PM
SBC’s had drain plugs as well. They actually worked better than the drain plugs on the LS platform. On my Race SBC stuff, I’d thread petcocks into the block down there, as we drained the coolant every Race.
Old Sep 30, 2018 | 04:01 PM
8.Lug's Avatar
The terms “flush” and “drain” are not interchangeable. The operation you described is flushing - however your thread title says draining. Not the same thing at all. You flush a toilet, you drain a tub - which one still has water it in afterwards?
Old Sep 30, 2018 | 11:13 PM
LLLosingit's Avatar
Obviously reading comprehension is not your thing, If you read the first post he wants to flush the old coolant out with a hose....Then drain the hose water out before refilling with distilled water and fresh coolant.
Old Oct 2, 2018 | 10:46 PM
00-Z28's Avatar
Thanks for all the tips guys, I just wound up flushing it twice with distilled water once the hose water was coming out clean, then I added the coolant. Everything worked out fine. Someone on here mentioned that they drain and refill their radiator every 6 months to keep the system fresh, I may start doing that from now on. I also don't have to worry about power steering fluid in the coolant anymore, she's got her own separate cooler now.
