Main side bolt sealer?
Old Dec 8, 2018 | 09:46 PM
boostedbird78's Avatar
Default Main side bolt sealer?
Is there some sort of a sealer that comes on the the flange of the side bolts for the main caps? Im worried about oil leaking from behind them. Let me know what youve done or suggestions.
Old Dec 9, 2018 | 12:08 AM
Use RTV on those. My source is "How to Rebuild GM LS-Series Engines" by Chris Werner.
Old Dec 9, 2018 | 05:51 PM
Agree with G. I’ve built quite a few ls engines, and I use grey rtv fairly liberally on the underside of the side bolts. If you do not use a sealant, they will leak.
Old Dec 9, 2018 | 07:22 PM
Good heads-up on the grade of RTV. That's where I was in the dark.... Something temperature-tolerant, I would assume....
Old Dec 9, 2018 | 08:47 PM
KCS's Avatar
KCS
Moderator
The stock bolts have an orange sealer under the head. I like to use Right Stuff on them whether its stock bolts or ARP.
Old Dec 11, 2018 | 10:08 PM
Philhippy45's Avatar
I used rtv sealer on mine and have no leaks.
Old Dec 11, 2018 | 10:21 PM
Good to know I have dependable sources! lol
Old Dec 11, 2018 | 11:24 PM
CattleAc's Avatar
I use Right Stuff exclusively in the shop...best sealant out there...
