bent header flange
Old Jul 16, 2019 | 04:44 PM
Floorman279's Avatar
Default bent header flange
bought some new in box 2 inch headers from kooks. got them coated. shop installed them only to find that it they leak. cylinder 1 and 3. pass side is fine. using mls a.c. delco gaskets. he said that sometimes stacking 2 mls gaskets will solve this problem so that's what he is goona try. I do have the kooks seal for good mls gaskets that have a bubble shape that looks like it compresses a little more. I think we could try that. any tips?
Old Jul 16, 2019 | 04:45 PM
the leak at the flange where they bolt to the head. so assuming they don't sit flat against the head
Old Jul 16, 2019 | 05:40 PM
Put a straight edge against the flange to see if it's bent, and if so, try to straighten it.
Old Jul 16, 2019 | 10:55 PM
I figured it may be that easy, but then thought maybe it bends in a way that makes straitening tough or something. I'll respond back after he tries 2 gaskets
Old Jul 16, 2019 | 11:10 PM
Nothing that can't be fixed with a torch and hand grinder. Don't overthink it.
Old Jul 17, 2019 | 06:21 AM
99Silver6.0's Avatar
Could always see if a machine shop can jig it up and mill off the high spots if you want to get real technical.
Old Jul 17, 2019 | 04:03 PM
My ARH headers are the same way. I doubled up two GM MLS gaskets and all is well. Pretty depressing to pay $1500 for headers that leak. You’ll likely hurt the coating trying to fix them.
Old Jul 17, 2019 | 09:54 PM
Yea it's funny cause I'm like darn shoulda went arh
Old Jul 19, 2019 | 01:47 PM
wannafbody's Avatar
My ceramic coated Hookers leaked at cylinder 8, You'd think theses companies could do a quality check before shipping stuff. My TSP headers were perfect.
Old Jul 23, 2019 | 10:30 PM
the double gasket fixed the problem
Old Jul 24, 2019 | 08:03 AM
hardtrailz's Avatar
AC Delco 12617944 Is that the right part number for the gaskets?
Old Jul 24, 2019 | 09:22 PM
Awesome!
Old Jul 25, 2019 | 10:17 AM
I didn’t have any problems with my ARH install. Fit amazingly well and great ground clearance. The TSP’s I tried before were an absolute nightmare.
