O2 Sensor Part Number for LT Headers- not Bosch
Does anyone have the part number or could at least tell me what to application to search for them under? I want to use AC Delco or Denso so those would be the part numbers I'm looking for.
Also, I have the rear O2s still but they are factory and have probably close to 100k miles on them. Would they be ok or would I get better gas mileage, part throttle performance from a new set?
I ran them for years without an issue (and yes the stock harness is long enough not to need extensions). When I did a new build 2 winters ago LS1tech moved on to prefer Denso sensors over Bosch so I cross-referenced the P/N and have Densos in now. Don't have it off the top of my head.
Maybe I could call an auto parts store to see if they could cross reference the part # for me. I'm pretty sure it's going to be this one but I'm not 100% and I don't want to order until I know for sure.
I wondered the same thing. I have never, ever have had an issue with a Bosch sensor, whether it be a narrowband factory replacement, a wideband sensor for an aftermarket EFI, or a sensor for any AEM wideband gauge. First I have ever read/heard of any issues.
Is this a recent issue?
If you search around on here about Bosch 13111 O2 sensors about 1/2 of the guys that run them have problem and others say they work fine.
Unfortunately, I immediately started throwing P0133 and P0153 DTC’s; Slow Circuit Response for B1& B2 respectively. At least my previous intermittent problems with DTC P0135 & P0155 (Heater Circuit Performance B1 & B2) were gone.
That being said, in the past four years or so, I've only run O2's for a total of about six months. Both times I installed a fresh set, I ran into torrential rains and street flooding that fried them because my collectors hang so low. So I've been mostly in full-time open loop.
