Exhaust manifold bolt question
my heads are currently off and im in the process or removing some of those broken studs (which i havent been able to) well i got 1 of 3. lol. Ive done soo many swaps and these always seem to be a pain.
By the way it's not the weight that's the problem, It's the reaction that happens when you bolt something together using dissimilar metals. Aluminum and steel don't play nice together over time.
i was just asking if there would be any issues installing bigger hardware. also think some of mine are stripped/cross threaded by previous owner. im not a fan of heli coils so id rather just drill a size bigger and tap it for a bigger bolt/ stud.
It does happen a lot, but the best fix is, ARP studs. A little expensive, but gives piece of mind and you won't have that problem again.
In my opinion, I would try to clean out the tread the best I can and see if I can get a bolt to catch on a few threads. It may be enough to keep a good seal. Again, buy the studs if you can. If this is no go, I would helicoil. Drill and tapping to a larger bolt would be last resort.
Heli-Coils are the way to go.
Not sure how "not being a fan" figures into REALITY, or how such a thing would even get started. They're really BY FAR the best way for most typical people like us to improve on the obvious weakest feature in a whole engine. I recall getting FSMs for Chrysler vehicles in the 60s, where in the transmission section, the first step in prepping for a rebuild after teardown was, "Heli-Coil all bolt holes".
yeah i usually try and clean any of the holes out pretty good. but these were already snapped inside when i bought the motor.
