RPM Tach is wacked?!?
Old Jan 9, 2020 | 12:43 PM
smws6ta's Avatar
Default RPM Tach is wacked?!?
My tach is reading 2300 rpms higher while under load and at idle 1000.
Is there a fix for this besides an aftermarket tach?
Old Jan 9, 2020 | 03:18 PM
A tach does not know if you're under load or not. It counts revs. How does it read when revving out of gear?
Old Jan 9, 2020 | 05:25 PM
smws6ta's Avatar
At idle it shows about 1000-1300 higher. When I rev up or driving when it's supposed to be 2600 rpms it shows it near 4000, at 4500 rpms it's in the high 6's.
Old Jan 9, 2020 | 05:31 PM
RB04Av's Avatar
What happened when you changed out the stepper motor?
Old Jan 9, 2020 | 06:16 PM
smws6ta's Avatar
It's been going out like this for a few yrs.
I haven't touched the inside of the cluster.
Old Jan 9, 2020 | 09:48 PM
What makes you think he did?
Old Jan 10, 2020 | 09:32 AM
smws6ta's Avatar
I never heard of this till you mention this, had to look it up.
I'm betting now this is what it could be, I mean after all the car is 22 yrs old. It can't even keep the dash pad from cracking after 6 months new down here.
I'll look for these, they seem to be cheap so I'll get some and swap them in and report back.
Thank you.
Old Jan 10, 2020 | 09:40 AM
smws6ta's Avatar
Well Hell, I called Scott Speedometer and he says there are no stepper motors in a 1998 gm product.
They didn't start using them until after 2003
Old Jan 15, 2020 | 01:22 PM
smws6ta's Avatar
Still haven't found any accurate info on this yet. I really don't want to tear into my cluster just to see.
Old Jan 16, 2020 | 07:56 AM
rpturbo's Avatar
Is this stock? Has it had a 99+ ecm swap done? Was it ever correct since you have owned it? If the car was tuned or the ecm was swapped, it could just be a tach setting in the tune, but I can't say based on info provided.
Old Jan 16, 2020 | 11:38 AM
smws6ta's Avatar
Tach and ecm are both stock. Only adjustment on the tune was for mph due to the rear being a 8.8 with 4.11 gr.
Old Jan 21, 2020 | 11:44 AM
smws6ta's Avatar
Ok, I got a hold of a dash cluster from 99 Camaro and this is what I found on the rpm.
So what is it?
[/url]
Old Feb 10, 2020 | 09:27 AM
smws6ta's Avatar
Well I'm not crazy.
I got an aftermarket tach and it's showing the same as the raptor shift light and what HP tuners shows the engine is reading.
I figure the $78 I spent on the gauge is cheaper test then sending it off to get it checked out/repair for $300. I'll see how this works for me for a while I may send it off when I have the money to spare.
Old Feb 12, 2020 | 04:47 PM
cino's Avatar
As a patch, have you considered Dakota Digital tach signal converter? You can adjust the signal in converter to tweak the output and correct tach in your cluster.
Is your tach needle at zero with key on engine off? If not, maybe you just need to move needle down? Just guessing here.
Old Feb 14, 2020 | 10:29 AM
rpturbo's Avatar
Well if the aftermarket tach is also reading off, then the source is confused. Sounds like the tach setting in the tune needs corrected. It's very simple.
Old Feb 15, 2020 | 08:53 AM
smws6ta's Avatar
Default ?
The aftermarket (AM) tach, the Raptor shift light both read correct, it's the cars tach that is off. I know you can adjust the speedo in the software but I don't think the rpm can. It just reads the inputs and reports. The ecm is reading the same as the AM tack and Shift light when you look at it thru Hptuners.
This AM tach was more of a temp but may end up as a permanent fix. Spent $79 for it vs $300 to send the cluster out and have it fixed, with no guarantee it could be fixed.
