Vacuum leak lq4
I them made a smoke tester out of a pump from harbor freight and a cigar, hooked it to the intake manifold. I discovered 2 more leaks. One from the egr and one from a line going to the fuel rail. I replaced the line and blocked off the egr. I then ran the smoke tester again and no other smoke came out from anywhere.
After this, my short term fuel trims both sides are in the mid teens and the long term is still pegged at 25%. I can drive it and the short term goes up in the high 30s. Around 1500rpms i can hear a whistle.
Is there any other line i should be checking? Intake manifold bolts are tight. I checked the pcv and the line going to the brake booster. What else can i check? Im not throwing any check engine lights, except the egr. I also cleaned the original maf and the replaced it.
Thanks
It shut off because the intake manifold gasket gave out causing a huge vacuum leak. The car wouldnt run at all until i replaced that gasket.
Or someone loosened all your intake manifold bolts? lol
Low fuel pressure would cause a lean condition.
Never heard of an intake gasket causing a die-while-driving. Ever. Not any kind of motor. Now please note, I am NOT saying "your intake gaskets were fine", NOT saying "put your old ones back", NOT saying "intake gaskets don't matter", NOT NOT NOT NOT NOT NOT NOT NOT NOT. Only, that intake gaskets don't cause the situation you found yourself in. Which is to say, no matter what you found out about them or did to them, the underlying problem is still in effect.
More likely, your fuel pump died as you were driving down the road, and the fuel trims couldn't adjust rapidly enough. THAT will make a motor die while driving.
Check your fuel pressure.
Im going to check it tomorrow. The gaskets were below the plastic that was holding them providing no seal. I also had 2 more vacuum leaks on top of that. My guess is all that unmetered air is what shut the engine down. Also, this happened 2 months ago and i still drive the truck everyday about 10miles without much issue other than the wacky fuel trims. It idles at 600 and accelerates fine. Im just trying to fix everything so i dont get stranded again.
Possible: I suppose; LIKELY: not so much.
Again, NOT saying your intake leaks didn't matter, or whatever else; only, that they did NOT cause a die-while-driving. Die-while-driving is a SINGLE POINT OF FAILURE, some ONE THING that suddenly just decided to retire right then, that's UTTERLY ESSENTIAL to driving. Vacuum leaks … aren't. The vacuum in a truck isn't even all that high while cruising at highway speed anyway, so not much unmetered air would have got sucked in. Run-like-crap, maybe; idle-terrible, ABSOLUTELY; die-when-you-take-your-foot-off-the-gas, FOR SURE; die-while-driving-down-the-HIGHWAY, NO.Especially not when after you've got it all "fixed", and the CAR ITSELF is telling you by way of wacked fuel trims IT'S STILL BROKEN. It might seem "fixed", because after the pump failed and the ECM had time to adjust itself to its new world order, the fuel trims have all gone as far as they can possibly go to one side, and it's feeding enough fuel that it seems OK; but if it was truly REPAIRED, as opposed to "fixed", the fuel trims would be back to near normal.
Should be high 50s, like 56 - 59 psi range. Possible: I suppose; LIKELY: not so much.
Should be high 50s, like 56 - 59 psi range.I understand the car isnt fixed. My point of this thread is exactly that. I also know it dying while driving isnt a single point of failure.
Fuel pressure with the keytin the on position is at 20psi with no bleed off. When i start it, it flutters between 15 and 22psi. Im honestly surprised this doesnt set a check engine light.
Is this a regulator or pump problem? Car always starts super quick. Im going to throw a new fuel filter in.
What are the next diagnosing steps?
Thanks.
You could try just changing out the regulator if it's only acoupla $$$ but somehow I doubt that's gonna give you much love.
I should also mention, be prepared whenever you DO get it straightened out, it's gonna SERIOUSLY RUN LIKE CRAP for awhile, until the ECM returns the fuel trims to near normal. In the meantime it's gonna DROWN itself in fuel.
And of course, ALWAYS a good idea to replace the fuel filter.
Thanks for the help in pointing me towards the fuel pump.
I'd recommend driving it around for awhile, let it relearn itself; then see where it stands.
Is the FP up around 58 or so now?
Sounds like progress is progressing.
Probably wouldn't hurt to take the injectors out and soak them overnight in lacquer thinner. Take the O-rings off first if you plan to re-use them. Which I wouldn't unless they're near brand-new. If that makes a difference, consider replacing them. Any number of injector service places can either clean & flow-match yours, or supply you a set like that for your trade-ins, or whatever.
