Chris1313 CAI and hood stability
Old Aug 16, 2020 | 12:26 PM
GTAWS6Brah's Avatar
Default Chris1313 CAI and hood stability
Seems there is some cutting of the hood latch support involved for this install. In doing so will the good latch be any less stable? Any negatives that come with making these cuts?
Old Aug 16, 2020 | 12:54 PM
Compromising structural integrity is not a good sacrifice for a smoother air intake. Cut the intake instead.
Old Aug 16, 2020 | 01:06 PM
FinalCam's Avatar
If you have his ac or non ac version, cutting the v bracket does not sacrifice integrity to a degree I would consider significant or noteworthy. I’ve ran both, but I have not ran his pro stock version. I used his ram airs on my DDs with no problem.
Old Aug 16, 2020 | 02:44 PM
GTAWS6Brah's Avatar
I have the ac version. Unaware of these ram airs you’re referencing.
Old Aug 16, 2020 | 03:11 PM
Fah Cue's Avatar
I have a pro stock with AC.
I know it's not the same, but latch supports have to be trimmed regardless.
Hit 130 multiple times last night.
Hood did not lift or flutter at speed.
it also shuts solid.
Old Aug 16, 2020 | 05:05 PM
GTAWS6Brah's Avatar
What’s the difference between yours and the regular one?
Old Aug 17, 2020 | 04:53 PM
Bob570's Avatar
The Chrs1313 is a ram air. The Chrs1313 that you want to install is a ram air setup.
Old Aug 21, 2020 | 03:22 PM
Magnet's Avatar
It does not cause any issues or instability. Don’t think twice about it
