Oil pan (am I screwed)**UPDATE**
Did h/c/I swap had my buddy under the car tightening the oil pan up while I buttoned things up on the top end and there is a leak now, I crawl under there to investigate and he stripped the damn bolt in the back of the pan I'm stressed and pissed off cause I got an appointment set with a tuner 🤬🤬🤬🤬🤬🤬🤬🤬🤬🤬🤬🤬🤬🤬🤬🤬🤬
Anyone got some tricks to fix this issue in the car? Dont have a way to yank the motor at my house
The following users liked this post:
G Atsma (09-19-2020)
Those are one of the really long bolts that thread into the bottom of the rear cover. OP, when you say stripped, do you mean spinning or the head is rounded (I can't really see in the picture). A few years back I had one snap while torquing it down and thought it was stripped, turned out it broke right before the threads and the gasket had just enough purchase to keep the bolt retained (I was able to turn the threads out of the rear cover by hand once I got the pan off). If you can't get the motor lifted and drop the pan, can you get the trans moved back to give you some room to work?
he also said the gasket would be fine to reuse so it was never pulled off just lowered down then re torqued down after reinstallation of the oil pump and pickup tube
This kinda kicked me right in the nuts after getting this motor all together but that's gonna have to be the route it seems
Best plan of attack I've decided so far is to grab an engine support from the top hook it up and then drop the k member down as far as I can and that should give me the space to lower the pan and get it out of there 😞
yes that is from the leak so my buddy who told me he did h/c/I swaps on these cars before said the pan would have to be dropped down in order to get the pickup tube unbolted so the oil pump can come off but I seen a couple write ups done where they did not drop the oil pan down so that was really annoying to see
I’ve seen people say they have got it as well but I don’t see how. I’ve done I don’t know how many of them... Trust me. Dropping the pan down was the correct move. I’ve reused gaskets with success in the past. These engines are getting older now and prefer to change stuff when I can
You can get the pan out with out pulling the motor or the trans. I just did one on a t56 car, drop the k-member as low as you can, you'll need to disconnect the steering shaft,pull the motor mount bolts and jack the engine up as far as you can and you can slip the pan out. I pulled the oil pump on my VVT delete without pulling the pan, it's not hard, just gotta take your time.
This ↑↑↑. I did the exact same procedure last spring. If you go this route, make sure to keep and eye on the steering shaft as you raise the K-member back into place. May as well replace the oil pan gasket if you didn't already. Also, now would be a great time to install a crank scraper. Good luck!
Moderator
Received 1,838 Likes
Am I missing something? That looks like the bolt that goes way up into the rear cover. If so, consider the possibility that you might need to replace the rear cover.
On the gasket, I will generally replace as the price of a new gasket is cheaper than my time plus pain in the add factor to have to go back.
The following 3 users liked this post by Darth_V8r:
I totally missed this^^^^^^^^^. The rear cover is a much easier job than doing the way-above-described repair. Likely cheaper too.
[QUOTE=Darth_V8r;20291958]Am I missing something? That looks like the bolt that goes way up into the rear cover. If so, consider the possibility that you might need to replace the rear cover.
Same though I had, best way to fix this is removing the transmission. Then easy-peezy
G Atsma (09-29-2020)
Moderator
If you do end up replacing rear cover get the saccity alignment tools so you do not get RMS leak
G Atsma (10-01-2020)
This whole situation has deflated my whole momentum lol I have not gone back into the garage to work on it sense I posted will probably go out there tomorrow i'm going to be really bummed out if I have to drop the transmission because of this crap sense I got ran over my right shoulder don't have the same strength it used to...wish people would stop texting and driving and I would have never been ran over smh...
Man after all the google searches i've done checking out different h/c/i builds, cylinder head information I have seen your name come up alot you have posted alot of good information in the past years I never get tired of reading good information so for starters thanks for all the good information you have put out over the years, but yeah that bolt is 1 of the 2 long bolts that go in now this maybe a dumb question but you're saying the rear cover would be leaking not the pan? or that because the thread is stripped out of the rear cover that I would have to replace it? I was figuring that because the pan was dropped than put back up there with the oem pan gasket it just did not seal right because it was not torqued down in the right sequence along with that bolt being now stripped I figure that the oil was seeping threw that corner
and I agree. Darth_V8r is very helpful on here.. i also notice he reply with a lot of useful information on here.. Btw I'd have your home boy that stripped it out do all the manual labor haha
Yeah I do not have a lift, wish I did lol, also dude has claimed he did not strip it so I guess casper the ghost went under my car and did it
Moderator
Thanks for the kind words.
I done exactly the same thing. Stripped that rear bolt. I then tried to tap it, etc, from the bottom, and it snugged up but still leaked. I ended up having to replace the cover. Your buddy probably does not realize he stripped it. It does not take a lot of Ugga-duggas to strip that bolt.
If you do want to try dropping the oil pan you can support the engine from the transmission. When you put the engine on a stand four of those bellhousing bolts support the weight. Usually I will split the load between the transmission and a cherry picker.
I just think after you do all that you will end up having to replace that rear cover just like I did. If you want to give it every chance of success, goop the gasket up with rtv. In my case, when I tried to tap the cover it cracked. I did not realize this until the cover came off.
Best of luck.
Btw, I do not know what I expected to read at the end of your post, but dang dude!
Best of luck.
Oh I'm going to be gooping some rtv for sure BUT I've stumbled upon this last night gonna try it out cant hurt if I end up having to replace the cover anyways and it says it makes threads that hold up to 128ftlb so it shouldn't have a problem with the 106inlbs if anyone here has not tried it I'm gonna be the test dummy on it.....I seen a video of the stuff and it seems like it should do the job
