Popping from header/exhaust?
Old Jan 5, 2022 | 02:20 PM
juan16's Avatar
Default Popping from header/exhaust?
I have a 2000 5.3, ive been having this annoying problem where I get this pop in my exhaust specifically around the header area. It only happens around 2000 rpm’s to about 2700. It’s feels like a hiccup but the truck will drive smooth other than that. It doesn’t happen at idle nor does it throw a code at all. Any thoughts?
Truck is full bolt on cam. Valves were replaced with cam.
Old Jan 5, 2022 | 03:30 PM
WHICH cam?
Old Jan 5, 2022 | 04:02 PM
juan16's Avatar
Originally Posted by G Atsma
WHICH cam?
228/228r tsp cam
Old Jan 5, 2022 | 06:34 PM
jetech's Avatar
Veteran: Air Force
will it happen in neutral? if it does you might be able to isolate the issue by pulling the injector wiring connectors or the coil connectors one by one.
Old Jan 12, 2022 | 04:40 PM
Tuning issue. It’s either going crazy rich, or very lean in that area of the powerband. I’d vote rich. Fuel mileage suck?
Old Jan 17, 2022 | 11:34 AM
juan16's Avatar
had my tuner run it for a week and nothing comes up says it could be a lack of spark?
Old Jan 17, 2022 | 11:42 AM
jetech's Avatar
Veteran: Air Force
Still have original plug wires?
Old Jan 17, 2022 | 11:43 AM
02*C5's Avatar
I had the snack crackle and pop before my tune and still have it after the tune when down shifting on my GTO. My tuner said that as long as it's not happening in under acxeleration load I was fine.
Old Jan 18, 2022 | 03:20 PM
juan16's Avatar
i have MSD wires
Old Jan 18, 2022 | 03:21 PM
juan16's Avatar
It happens only under acceleration, Im pulling my plugs to see if they have too much carbon deposit maybe? The only thing I’ve heard it could be is unburnt fuel that’s falling into the exhaust and exploding with a hot header causing a pop sound.
Old Jan 26, 2022 | 08:56 PM
02*C5's Avatar
then that's not good that means there's detonation happening in your cylinders and that could be a bad sign of worst things to come. Detonation is when fuel is being ignited before TDC and it will hurt your bearings and so on. Do you have a tune done and what fuel octane was it done on and what fuel are you running in it?
