3-Bolt to 4-Bolt TB
Thanks for any suggestions.
The 78mm snout is the biggest LS6 intake restriction.
The 90/92mm TB will work great on matching Fast intake or LPE/TPIS mod'd 90mm snout LS6
The reason I’m asking is that I have another engine platform (Gen 6 BBC) that uses the same 3 bolt throttle body as the LS engines, except that there are no alternative sized intake manifolds available to utilize a larger throttle body. I want to go to DBW and already have a stock truck 4 bolt DBW 90mm TB and a 3 to 4 bolt adapter, so it makes sense to use this rather than spend more money to source a 3 bolt DBW TB.
It seems to me that the CFM rating on the stock 78mm TB was likely already undersized for my particular application, so I see no harm in upgrading to a 90mm. In fact, I’d almost be willing to bet that there is a measurable improvement even if the intake is the bottleneck in the system.
Here's a few possibilities where a fat TB on a skinny snout intake might show some benefits.
1) Cracking a 92mm TB open 15% at part throttle should move more air that 15% at part throttle on a 78mm TB, so the bigger TB might "feel" more responsive on a 78mm snout intake.
2) With an air ram set up like a Fast Toys ram air or Chris1313 or Douggie Box with a big intake route to move air and pressurize the intake track at higher speeds the momentum of air might jab some more air past the 78mm snout "restrictor plate" and show a gain at the drag strip. However if going to all of that prep and expense getting a 90/92 mm snout intake would make sense. $350 for adding snout to LS6 intake by TPIS or LPE or buying a Fast 90/92.
Ultimately only way to know "for sure" is careful dyno testing.
3) Tricks and techniques that help improve air flow & hp when a restrictor plate or defacto restrict or plate is used on an engine. Once could even go crazy and use a reverse pattern cam like 230/224 like the old days when we were stuck with just the LS1 intake manifold etc
sounds like a job for math...
wish I had mad math skills.
