Cleaning an Alternator?
Old Mar 29, 2023 | 11:17 AM
mblair's Avatar
Default Cleaning an Alternator?
TLDR: Power steering pump puked its guts out over winter in storage and my (2 year old) alternator is covered in oil. Can it be cleaned by me using parts cleaner or something of the sort if done carefully?
Continuation: Is the alternator trashed? I'm upgrading to a corvette style pump and remote reservoir mounted up by the Brake booster.
The current alternator was installed as a condition of my purchase as it was proven to be junk. I opted for an upgraded 165 amp powermaster for them to install, so it's a unit I'd like to reuse if possible.
TIA!
Old Mar 29, 2023 | 01:38 PM
sjsingle1's Avatar
when my PS pump puked all over the alt....trashed the brushes
Old Mar 29, 2023 | 02:12 PM
mblair's Avatar
Did you replace yourself/have it rebuilt or trash it?
Old Mar 29, 2023 | 03:37 PM
sjsingle1's Avatar
i got another alt....but plan to replace the brushes in that alt
Old Mar 29, 2023 | 03:54 PM
Gene Cheeseman's Avatar
Did you determine that yourself? If so I'm just curious what it did to the brushes.
Old Mar 31, 2023 | 03:35 PM
ghardester's Avatar
You want to use this cleaner, it is expensive but works. It will sometimes disolve plastic parts but for an alternater just spray the **** out of it, let it drain and dry, and you should be good to go.
Amazon.com: CRC 05018 Lectra-Motive Electric Parts Cleaner - 19 Wt Oz. : Automotive Amazon.com: CRC 05018 Lectra-Motive Electric Parts Cleaner - 19 Wt Oz. : Automotive
Old Mar 31, 2023 | 06:07 PM
pdxmotorhead's Avatar
The brushes are carbon, if they sit in oil very log they will soak it up.
But thing is to pull the alternator, take it apart and swap the brushes and use the electroclen spray top clean the armature and case,
Try not to directly spray the bearings with the Electroclean it will get past the seals, if the alt is very old, a new set of bearings can be put in
at the same time, its a little fussy but definitely a diy possible job.
Trick, there is a pinhole in the case that matches a pinhole in the brushes holder, a paper clip slid in
will hold the brushes up while you put the thing together then pull the clip to release the brushes.
Old Apr 1, 2023 | 12:19 AM
sjsingle1's Avatar
brushes soaked in oil or any other not so nice fluid does not let the brushes do their job
Old Apr 3, 2023 | 02:44 AM
Stlco60's Avatar
I thought about this!
Old Apr 11, 2023 | 12:07 PM
Diavg38's Avatar
Cleaning works but replacement is perfect.
