Adding A/C
Old May 20, 2024 | 10:06 AM
gcallahanWS6's Avatar
Smile Adding A/C
Hey guys I bought a 2001 firebird that has been 6.0 swapped. All the A/C components under the hood have been pulled out. Can anybody help me with a parts list of what I will need? Also what compressor bracket should I be looking for?
Old May 20, 2024 | 04:57 PM
B52bombardier1's Avatar
Are you looking for OEM Pontiac original AC items or an aftermarket kit from Vintage Air, Classic Auto Air or Nostalgic Air?
Rick
Old May 20, 2024 | 05:19 PM
OEM if possible.
Old May 20, 2024 | 05:26 PM
Junkyard would be your best bet. Find a car closest to yours for car-based parts, then a late truck for engine-based parts. Any good A/C shop should be able to connect everything.
Old May 20, 2024 | 06:27 PM
RB04Av's Avatar
Which FEAD do you have?
Old May 22, 2024 | 06:46 AM
Y2K_Frenzy's Avatar
I don’t know how much luck one will have with a junkyard looking for twenty five year old parts. If they even have an old F body on the yard you’re still buying nearly thirty year old parts that have been used as rat condominiums for the last twenty years at least.
Old May 22, 2024 | 09:15 AM
You get the CORRECT parts setup at the junkyard, then at the parts store get replacements for those parts that may be worn or damaged.
Point being, you will then have the CORRECT parts to replace, if needed, with CORRECT new parts.
Old May 22, 2024 | 11:49 AM
RB04Av's Avatar
First thing you need to know is, which FEAD you have. (front end accessory drive) Obviously this includes the compressor mount & drive. It also includes the crank damper, water pump, and alt/PS bracket(s).
There are 2 that are likely: the truck one (might have come with the engine), and the F-body one (came with the car, if it had a V8 to begin with... we don't know that either). Which comp M&D you need will depend on what you already have. If I were the guessing kind, I would guess you have the F-body one (original to your car), because the truck one is not easy to get to fit in a F-body (alt is in the wrong place, rad hose is incompatible, etc.) butt until you tell us, we can't know that.
What you will need to restore the AC will depend on which "A/C components under the hood have been pulled out". Lines? Accumulator/dryer? Evap housing? Blower motor? "All" is a pretty big word for such things. Nobody out here can give you a "parts list" without knowing what's missing; and even then it's likely to be at least somewhat inaccurate.
Old May 22, 2024 | 11:57 AM
Y2K_Frenzy's Avatar
I bet all means all this time since it’s a swap. Lines, evap, drier, compressor, high/low pressure switches.
Old May 22, 2024 | 12:05 PM
I’ll take some pics when i get off work. It has HVAC box, blower motor, all the goodies that are inside the car but everything
under the hood is gone even the brackets
Old May 22, 2024 | 12:09 PM
Y2K_Frenzy's Avatar
The bracketry might be the hardest to come by new.
Old May 26, 2024 | 11:23 AM
