Stuck IAC causing idle and misfire issues?
Been going down the diagnosis chain for a while now and haven’t come up with anything for why it backfires so much throughout the entire rpm range
When key gets out into in position, IAC makes a noise. Along the lines of “wawawawawa, brrrrrrrr” as if the valve was closing. When engines running it doesn’t move. When keys off makes the noises again.
With it out of the throttle body and key off. It was extended, so I would push the plunger back in. Once key hits on, noise happens and it would extend back out. After key turns back off, noise happens and it stays extended out.
With the truck on and just tape over the orifice, it actually sounded normal for about 30 seconds then would start backfiring again.
And the plunger would not move with the engine on too
ive got 12v at 2 of the pins and the other 2 are grounds I believe.
Would an IAC valve that is stuck closed cause a misfire w/o code?
Ive done all the first steps (compression; swapped plugs, coils, plug wires; swapped injectors, etc) just boiling down to all the stupid small ****
Also, more info. Is this a stock engine and harness or modified?
02’ Lm7 Th350, Cammed, stainless dual exhaust, “cold air intake”, PSI standalone but modified to fit into the truck harness. Is tuned for the swap and cam
If I’m being honest, when it was taped over, I don’t recall any backfiring and a smooth idle. However I had to turn it off as what I believe was my power steering pump low in fluid making an ear splitting whine.
A question I have, is that are IACs supposed to make any clearly audible noises? I mentioned it before that it makes a noise when the key turns on and off
it’s got a truck Norris, .560 lift springs, and 7.400 pushrods. All new parts.
I’ve already pulled valve covers and checked For broken springs, pushrod straightness, torque specs, etc.
ive got 170-180 compression on all cylinders
No audible hissing of a gnarly vacuum leak
Could there be something messed up with the tune involving IAC considering when the tape is acting like the IAC is all the way open resulting in a clean idle?
Lmao I actually already bought one before I made this thread. I’ll admit I actually broke the IAC I had in there…. I was messing around with it as it was extended out and I pulled it out further by hand and turned the key on. It then shot the plunger off to narnia and I couldn’t find it… The new one should be here Friday along with my fuel pressure gauge
Another thing, I’m not sure what has to happen to trigger a LTFT but could something like that, that it gets at idle, be causing the backfiring to extend throughout the rpm range?
If it's really noisy it can be a sign it's failing.
it shouldn't cause a backfire, only idle issues. backfires are usually from ignition or valve timing being incorrect, burnt valves, unburnt fuel in the exhaust, etc.
It seemed to help it quite a bit from what it was before. However now, for maybe a minute or so it has a nice idle. Then it goes back to heavily backfiring
I was able to log it,I’m just unaware of how to read it as it was logged through Torque on an android tablet and is saved as a .csv file.
Edit: I dont't believe I had my logging set up correctly to be able to show you guys. I opened the .csv file into sheets and only shows GPS and location based stuff
