Camaro alternator on GTO engine?
I’m looking for a Camaro alternator, but I want to make sure I’m getting the right thing. Specifically, I don’t know what the correct amperage would be, as I don’t know if it’s going to mess with the different ECU, nor do I know if the Camaro and GTO use the spacing (I believe that do, but I want to confirm).
So, with that said, does anyone have any alternator recommendations?
I believe the stock alternator for a 04’ GTO was 115amps. That size will suffice unless you have added power hungry accessories which could warrant a larger alternator.
If the vette was externally regulated (I’m not certain) you can jump the wires in the plug to allow for the new style alternators that are internally regulated.
Not sure if a 105amp alternator is going to be enough to power the GTO’s engine. Also, from what I’ve seen, Camaro alternators either come in 105amps, or super high output 220amp models. Would there be any concern with me throwing a 220amp alternator if I don’t actually need it? Would I have to upgrade the Corvette’s wiring to handle that?
No more one way street for you.
Try helping out some time.
good luck on whatever ur building.
To be fair…I’m an idiot, no one wants my help.
I’m usually getting information from a number of different forums and they all blend to together at a certain point. If I didn’t thank anyone, it wasn’t intentional. But point taken.
Appreciate the help!
With that said, the electrical demands of an LS1 engine will be higher than the stock L81 that came in your '81 C3, but anything in the 105-140amp range will work fine for this application unless you plan on a bunch of other high-amperage-demand features (such as a powerful aftermarket audio system, massive/multi-pump fuel system for huge power, tons of electronic interior gadgets added, etc.). If you're going to be drawing a TON of amperage, and fitting an alternator that can provide such amperage, then wiring will need to be equally matched to avoid blowing fuses (best case) or fire risk (worst case).
I don’t think I’ll be drawing a ton of amperage. I’ll be running one internal fuel pump, electric fans, electric gauges, and that’s about it. I’ll likely add a touch screen double din head unit in the future and will have a modest sound system, but those are really all the electrical upgrades I’ll be making, I think. And I can’t see those drawing TOO much electricity.
I think I’m just gonna send it with the original 140amp GTO alternator. I wasn’t able to get it in place, the only issue is that the I can’t connect the rear bracket to the block, as the rear of the alternator sticks out a tad too far. But the bracket has three mounting points already, so I’m thinking I should be alright. If the belt starts to squeal, I’ll replace the alternator with a higher output one that allows me to use the rear bracket.
Thanks for the help, this was super useful information!
There is no specific age-related period when wiring or connectors will become marginal as overall usage (mileage) and ambient conditions over a given period can vary greatly from one car to the next. For example, the fan wiring and connectors on my '98 are assembly line original; at 27 years old (but only 19k miles and garage storage) they are perfectly fine.
