Timing cover sub flush of block - help!
I put my balancer on with timing cover loose then torque my timing cover. The oil pan was on and hand threaded the front bolts.
Then attempted to put an f body oil pan Holley 302-1 knock off. I noticed the timing cover is sub flush of the block. By 1/16 ish (I didn't measure). Engine is on a stand I was going to loosen the timing cover and snug the bolts with 1/4" ratchet, put a level on the back of block to make it flush (transmission is not mounted). The tighten (not torque) the rear bolts, then the same on the front to get the timing cover flush or barely sub flush. Then loosen all bolts and torque in the proper sequence. I forgot I centered the timing cover by pressing the balancer with the bolts loose!
Is that an okay plan or any recommendations?
Alright and it's ok it the timing cover is a bit below the block?
I think I saw that tip in Car Craft magazine.
I have read multiple people aligning the timing cover with the balancer when pressing it on with success.
My understanding was that with the timing cover loose the crank pulley would center the timing cover.
Maybe I should ask the question differently, with RTV in the covers of the oil pan gasket is a leak likely with the timing cover below the block? I can measure tomorrow.
OR
Do I need to pull off the crank, replace the crank oil seal, get an alignment tool, and align the cover?
I have to take my balancer bolt off to pin my crank anyway. Thank the good Lord I got the ARP crank bolt!
