92mm Throttle Body cable adjustment Help!
Ive just swapped a 92mm chinese "knock-off" throttle body onto my LS1, and can only get to roughly 92% WOT with the pedal fully depressed.
Ive adjusted the slack out of the cable running from the cruise control module to the throttle body by tightening it until it just barely begins to pull the throttle blade open, and locking down the clip.
Is there any other adjustment/slack that I might be missing? Is there any way to get the last little bit of travel out of this cable setup that I might be missing??
Thanks!
(2004 GTO, LS1, W/ TCS)
The TCS will add to slack in the system. The Cruise stuff has absolutely nothing to do with anything when you are in it trying to get power.
Get rid of the TCS and run a single cable from the Pedal to the Throttle Body, then go from there.
Gas Pedal is a steel rod, which can be bent very easily and that's how I fine tune my cars for WOT settings.
