How to get rid of slight rasp with hooker and ory setup???
Old Aug 1, 2004 | 09:05 AM
Raise's Avatar
Default How to get rid of slight rasp with hooker and ory setup???
i just switched from true duals to an ory pipe and hooker aerochamber catback. i love the sound...and there isnt much rasp, however it is noticeable sometimes. what could i do to totally ger rid of it....could i maybe put a bullet in the i pipe? i dont wanna go to cats...though i know that would work......suggestions pleez?
Old Aug 1, 2004 | 10:54 AM
slik98z's Avatar
a bullet in the I pipe definately willc ut down on most of it. Might still have a little around 2k rpms, but it will definately be muffled to a point that its tolerable.
Good Luck!
Travis
Old Aug 1, 2004 | 11:15 AM
Tiger2o69's Avatar
What is the best flowing/sounding bullet?
Old Aug 1, 2004 | 12:54 PM
dug's Avatar
dug
A pair of bullets in the ypipe would do a better job reducing rasp. dynomax bullets are the ones people use. Magnaflow makes bullets but they only go up to 2.25" internally.
Old Aug 1, 2004 | 12:59 PM
Dope's Avatar
Dynomax bullets are the only way to go. They make them up to 4" I think and are straight through, and very compact, and cheap.
Dope
Old Aug 1, 2004 | 01:02 PM
Trans Am WS6 RGS's Avatar
Before I even read your post I knew you didnt have cats on. That pretty much tells you my suggestion.
Old Aug 1, 2004 | 01:18 PM
FI FREAK's Avatar
formerly BlacKSS2oo2 (9-20-2012)
who cares about the rasp. If u were so worried about it u should of bought cated ory.
Old Aug 1, 2004 | 02:13 PM
slik98z's Avatar
the bullet will get rid of the rasp.
Old Aug 1, 2004 | 03:19 PM
LS1LT1's Avatar
Lightbulb
Old Aug 1, 2004 | 06:06 PM
Raise's Avatar
so one bullet in the i pipe...or two in the y pipe?
Old Aug 1, 2004 | 07:12 PM
dug's Avatar
dug
A pair of bullets in the ypipe will do a better job of reducing rasp. Im not sure how practical it is with the hooker ory.
Old Aug 1, 2004 | 10:46 PM
Z-286speed's Avatar
Man, i have a bud that has macs with an ofy with the hooker setup in the back, and it had no rasp at all. But, throw some bullets in there, maybe find a 8 inch bullet. I would go with either two from the headers, or two where they put the loudmouth muffler in.
Old Aug 2, 2004 | 01:34 AM
Damian's Avatar
LSX Mechanic
Screw a bullet....
The key to killing rasp on these cars is in the COLLECTOR. Most people do not realize this, but when running a smaller collector on these cars you will get more rasp.
Get yourself a Flowmaster 3.5 inch collector to be welded onto your Y-pipe, and not only will the catback sound deeper, but 99% of the rasp will be gone..
Old Aug 2, 2004 | 10:40 AM
Rick-LS1's Avatar
Originally Posted by Damian
Screw a bullet....
I am having the same problem with rasp on my hooker ORY might get the flowmaster collecter with the bullet to add to my already installed Magnaflow cat back....Hmmm
Old Aug 2, 2004 | 09:32 PM
Tiger2o69's Avatar
Did the ORY part in the title give it away maybe???
J/k
Old Aug 2, 2004 | 11:52 PM
Raise's Avatar
yeah but how will the flowmaster collector fit on to the headers? my pacesetters have no collector on them
