oil temp and tranny temp guage install????
Old Aug 3, 2004 | 07:41 AM
fattdaddyLS1's Avatar
Default oil temp and tranny temp guage install????
Did a search but couldn't find anything on were to install the senders for both of these guages!
Old Aug 3, 2004 | 09:57 AM
Brandon_TA's Avatar
I'm guessing its an A4?
Old Aug 3, 2004 | 11:37 AM
2001 White Ws6's Avatar
Here is the writeup i used when i did my tranny temp gauge install. There is an area on the driver's side of the transmission where you can put the sender.
http://www.black98.cz28.com/photo6.html
Old Aug 3, 2004 | 03:55 PM
Thanks how about the the Oil!
Old Aug 3, 2004 | 05:03 PM
Ferocity02's Avatar
Not sure about the oil, but the tranny temp goes into the drain plug in the tranny. I'd assume you can put the oil one into the drain plug too. Thats what I would do.
Old Aug 4, 2004 | 12:26 AM
No one has this guage!?!
Old Aug 4, 2004 | 01:34 AM
Ferocity02's Avatar
Just put it in the drain plug. Done!
Old Aug 4, 2004 | 06:25 AM
mitchntx's Avatar
I removed the oil level sensor and used that port in the pan for engine oil temps.
It's a 20mm x 1.5 pitch thread
Old Aug 4, 2004 | 09:31 AM
ZigZagZ's Avatar
Try this
WWW.XSE.com/leres/ss
