asp pulley spun on crank
Old Aug 3, 2004 | 12:31 PM
Red01Chevy's Avatar
Default asp pulley spun on crank
did anyone ever have a problem with this??
luckily it didnt mess up the crank too much just a few scratches but it galled up the pulley
i called asp and they said to send it to them and they said they would "look at it". i sent it today so they should get it thursday or so
Old Aug 4, 2004 | 12:25 PM
Red01Chevy's Avatar
i dont guess this has happened to anyone
Old Aug 4, 2004 | 01:16 PM
2xLS1's Avatar
What procedure did you use for tightening the bolt and was a new bolt used?
Old Aug 15, 2004 | 10:28 PM
Red01Chevy's Avatar
it was a new bolt and i torqued it to 240ft-lbs
Old Aug 15, 2004 | 10:29 PM
2xLS1's Avatar
Well that was not the correct procedure.
Old Aug 15, 2004 | 10:30 PM
v8maro's Avatar
how is that not correct??
Old Aug 15, 2004 | 10:34 PM
HavATampa's Avatar
Tighten it to 240 ft. lbs. or until it is completely seated on the crank snout. Afterwards, REMOVE THE STOCK BOLT and replace it with the NEW CRANK BOLT. You will tighten the NEW bolt to 37 ft. lbs. and then turn it an additional 120 degrees. Still, you wouldn't think it would spin on the crankshaft though. That blows.
Old Aug 15, 2004 | 10:41 PM
v8maro's Avatar
Ahhh yes, maybe that's what he meant to say??
Old Aug 15, 2004 | 11:04 PM
2xLS1's Avatar
How am I supposed to know what he meant to say. I based my reply on what he said.
Old Aug 15, 2004 | 11:09 PM
Mike K.'s Avatar
Same thing happened to me with my ASP pulley,, Mine was tightened with an arp bolt though and was on a forged callies crank so maybe the diameter was just a hair different than the stock one??? What initially clued me in was low alt voltage, I actually replaced the alternator before I realized that the damn crank pulley was spinning on the snout, I removed the pulley and bolt with my bare hands and no tools lol. After that I put in a key and an ATI pulley just incase.
Let me know how it goes with your talks to ASP, I would love to be able to get a replacement for my pulley at least so I could sell it.
