Will the TSP duals bolt up to my stock exhaust manifolds?
1 Post
No they will not. The TSP true duals were fabricated using LT headers as the starting point. Of course you could buy the setup, and then have an exhaust shop mate it up to your stock manifolds and cats.
$notworththemoneyspent.00
would you consider getting long tube headers?
If you are going to stick with stock manifolds, id suggest going with 2.5 inch true duals. this way you could use the flanges from a stock ypipe so you can unbolt the true duals. just a thought
I will eventually be getting LT headers, but cant for another 40,000 miles (my warranty expires at 100k). I was thinking even if they welded the true duals to the stock manifolds, when I get LT's I could cut and re weld. Would this work?
the dealership will allow you to have true duals dumped before the axle but not long tube headers?? I think you may want to speak witht hem about this first if the warrenty means that much to you.
As you might be able to tell I'm not one that likes warrenties. when i was 13 and my dad was buying a car, i watched him take the warrenty papers outside at the front window and take a nice long **** on it then walk back inside. ever sense, i've learned if you rae going to pay goo dmoney for a car, you might as well do what you want done to it and enjoy it while it lasts...
