Mac Mids Installed. Problems!!!
Old Aug 16, 2004 | 04:55 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
Default Mac Mids Installed. Problems!!!
i installed the mac mids with ORY and when i pulled out of the garage i couldn't turn the steering wheel. what the hell, the steering shaft is hitting the driver header. has anyone else had this problem with there macs. oh yea it sounds like crap with a flowmaster at acceleration but at full blast it doesn't sound bad. what muffler sounds good with this setup. and i noticed a big power drop, its a dog of the line now.
Old Aug 16, 2004 | 05:04 PM
Ashtongsr's Avatar
The reason it sounds like crap is because you have an ory with no cats most likely. To fix this you are going to need to add a bullit resonator into the I-pipe to cancel some of the rasp. The real solution is to ditch the y-pipe and buy an xpipe and run true dual exhaust. As for the steering shaft hitting the header, I really have no experience there.
Old Aug 16, 2004 | 05:07 PM
NastySSoo's Avatar
Thats the first I ever heard of it with Macs. Sorry I cant help!
Old Aug 16, 2004 | 05:32 PM
jlrz28's Avatar
10 Second Fun Car
I intalled my Macs also didnt have any problems with the steering as far as being raspy thats jsut something you have to deal with. I have a SLP dual dual and it sounds good and I also have Metallic Cats, its still raspy.
Old Aug 16, 2004 | 06:21 PM
glennhl's Avatar
I had the steering knuckle rub on my primary tubes. Loosen the three bolts that hold the steering column to the firewall and move it away from the header and retighten. You may also have to grind down the bolt length and bolt head a little bit, but don't go too far.
Old Aug 16, 2004 | 06:46 PM
David901's Avatar
Why the drop in power???
Old Aug 16, 2004 | 08:13 PM
NOBR8KSS's Avatar
Drop in power is probably from false knock....a result of the header banging on the steering linkage.
My MACs fit excellent and I have never heard of any with fitment problems until today. As for the sound, try replacing the y-pipe collector with the Flowmaster 2.5" to 3" collector and then swap to a Hooker cat-back. The 80 Series Flowmaster cat-back is going to restrict your power pretty bad anyway, so just junk it.
Almost every y-pipe on the market needs to be modified to be decent, as the collector sucks on plenty of them.
Old Aug 16, 2004 | 08:38 PM
james hemme's Avatar
PARTS THIEF! BEWARE
Default sunset ss
i just bought some macs for my ss hope i dont have any problems.whats the easiest way to install them.I've got the slp loud mouth on there. 2002 sunset ss K&N,B&M ripper shifter,slp lid,mass air sensor,eibach sportline springs,mac headers ory,ls6 intake,smooth bellow,alum slp driveshaft,msd wires,tr55,Zo6 17x9.5,nittont555front,drag radials,back james02ss
Old Aug 16, 2004 | 08:40 PM
there is a noticable drop in power. off the line and cruising at40 and flooring it. what gives. if anything it should have more i also did a plug and wire change.
Old Aug 17, 2004 | 06:46 AM
NOBR8KSS's Avatar
Definitely sounds like false knock retard...those knock sensors are very sensitive...fix the banging/rubbing problem at the steering knuckle before deciding they are crappy....I picked up 22 rwhp from mine untuned.
I would call the sponsor who sold them to you and let them know your set may have been bent during shipping cuz it doesn't fit right.
Old Aug 17, 2004 | 09:06 AM
Derek98z's Avatar
sounds like the knuckle is installed 180* off. It's bending the wrong way I guess.
Old Aug 17, 2004 | 09:41 AM
CaptUSA's Avatar
Am I the only one wondering how you noticed the power drop if you can't turn the steering wheel? I know drag racing is a staight line, but come on now.......
Old Aug 18, 2004 | 06:36 PM
can some post a pic of there driver mac installed on the car so i can see what the difference is.
Old Aug 18, 2004 | 08:32 PM
-Q-'s Avatar
-Q-
Me too. I just envisioned "full blast" and "couldn't turn the steering wheel" and the results were not pretty.
