Examples of rasp.
Old Sep 3, 2004 | 10:01 AM
monyhunter's Avatar
Default Examples of rasp.
I don't care if you all want to give me a bunch of crap for this question, but all this talk about raspy exhausts, and I don't know if I've ever pinpointed what rasp sounds like. I've downloaded like every single exhaust file on ls1sounds.com. Can someone find one of those clips that has a lot of rasp and let me know.
right now I have the slp D/D with Magnaflow muffler, and it sounds good for now. Next step is LT with catted Y, then comes GMMG
Old Sep 3, 2004 | 10:06 AM
MeentSS02's Avatar
Kleeborp the Moderator™
You will only hear rasp if you ditch the cats, which it doesn't look like you are doing, so why are you even worried about it?
If you are looking for a clip, find someone with the Loudmouth with an ORY...that is the epitome of rasp.
Old Sep 3, 2004 | 10:11 AM
NOBR8KSS's Avatar
Also, you won't be able to hear it without a load on the engine...so listening to sound clips that just rev the engine or do a drive by at a consistant rpm won't make the rasp. As MeentSS02 said...MAC headers, catless y-pipe, and Loudmouth cat-back have it the worst I have ever heard.
With that exhaust, the rasp will be the worst in top gear at 2000 rpms and then floor it through about 3000 rpms...it is unmistakeable and quite horrible.
Old Sep 3, 2004 | 10:27 AM
GregWS6&z28's Avatar
i have MACs adn ORY and it's horrible 2100-2500 with my dynomax bullet, so thats very close to what the loudmouth would be. It's quite obnoxious so I'm ordering a Borla XR-1 muffler to tone it down some. That will probably be as far as i can go.
if you wanna hear kidna what rasp sounds like, it reminds me of a tractor trailer downshifting and laying on the jake brake, it just screams!
matty169's Avatar
Default Dont like it!!!
I have mac headers, ory, no cats,full MAC exhaust and I hated it until I added a large tube/bullet muffler.
Old Sep 3, 2004 | 10:41 AM
m_donze's Avatar
It's only rasp if you go slowly through that rpm range. If you floor it through the range it sounds like pure power. In 4th gear you can hear me for miles. I'll get a clip up as soon as i can.
Old Sep 3, 2004 | 10:59 AM
Jorday's Avatar
I used to have a catless y pipe with my mac headers a long time ago and I had the raspy sound until I put bullet mufflers in the y pipe.
Old Sep 3, 2004 | 11:12 AM
monyhunter's Avatar
If you go here http://www.magnaflow.com/04sound/domestic.htm and listen to the two camaro clips, is rasp the sound that is made after you get off the gas? I have always thought rasp was the sounds when you are decelerating, but I think I'm wrong.
Old Sep 3, 2004 | 11:17 AM
RahuL's Avatar
Originally Posted by monyhunter
If you go here [url].... is rasp the sound that is made after you get off the gas? I have always thought rasp was the sounds when you are decelerating, but I think I'm wrong.
that's backpressure.. I thought it was rasp too.. but it's not
Old Sep 3, 2004 | 12:54 PM
z98's Avatar
z98
I wouldn't worry about rasp too much when you're getting a ticket for doing 130 mph.
Old Sep 3, 2004 | 12:59 PM
777's Avatar
777
i have the perfect video of rasp...i don't know if its on ls1sounds or if i can post it but ill try..
edit: i can't...if someone can tell me how to then i will...its an 02 ws6 pewter...and sound pretty bad
Old Sep 3, 2004 | 01:10 PM
Lucian's Avatar
an easy way to think about rasp is that popping sound when you are accelerating in the range of 2100-2500. Have you ever heard an old truck with cherry pipes while the rpm's are dropping drastically? that is what it sounds like, except it is lot more rapid in effect
Old Sep 3, 2004 | 03:07 PM
PHANTA-Z's Avatar
Being a former loudmouth owner, all i can really say on this subject is, you'll know it when you hear it. Its that sound that seems like its only reason for existance is to make the hair on the back of your neck stand up and give you this undying urge to claw at your ears. Grating, incessant, nasty, crappy noise. The opposite of a deep, smooth, mellow growl. Its also the sound that occurs at precisely the times your crappy, raspy exhaust is rattling/vibrating things in the interior of your car. Thats about it.
Old Sep 4, 2004 | 08:41 AM
Ojustracing's Avatar
It sounds like a metal coffee can with a piece of metal rod rolling around it at a high rate of speed. John
Old Sep 8, 2004 | 04:43 PM
monyhunter's Avatar
I have nearly every single audio/video clip downloaded from ls1sounds.com. I have spent a lot of time listening to all the different exhaust sounds. However, because I'm not really sure what rasp sounds like, do any of you know off hand some of the sound clips that are a good example of rasp? Could you post a link for me? Thanks a ton.
Old Sep 8, 2004 | 07:44 PM
Ferocity02's Avatar
Here is a beautiful thread for your question....
https://ls1tech.com/forums/showthread.php?t=184951
Big font makes it easy to see, hard to miss
It's amazing what a little searching will do... I got your back on this one jrp
Old Sep 8, 2004 | 07:51 PM
Ferocity02's Avatar
Ok... well most of those links dont f'ing work anymore... I'll find more, give me some time...
Old Sep 8, 2004 | 07:58 PM
Ferocity02's Avatar
Raspy:
http://www.ls1sounds.com/SLPloudmout...114_timcam.wmv
http://www.ls1sounds.com/SLPloudmout...nORY_98Z28.wmv
Clean:
http://www.ls1sounds.com/Flowmaster/...er_stockTA.MPG
http://www.ls1sounds.com/Flowmaster/...tock-00Z28.MOV
Old Sep 8, 2004 | 09:08 PM
monyhunter's Avatar
Ferocity02, thanks a ton for the links. That is exactly what I needed to help me "hear" what rasp is. For everyone else that replied, thanks as well.
However, I'm really getting sick and tired of seeing someone post on every other thread, "amazing what a search will bring up", or something like that. Just because some of you "experts" mostly post answers instead of questions doesn't mean you have to constantly be reprimanding us newcomers to the f-body world for not searching every single time, or not being able to find exactly what we are looking for. I'm not trying to be an ***, but you can do without the condisending, "do a search" remarks most of the time. (however, this is not true for those questions like, 'what's the best sounding catback'".)
I probably just opened mouth and inserted foot...oh well.
Old Sep 9, 2004 | 12:07 AM
mnc2886's Avatar
Um, this might seem dumb, but pronounce the word "rasp" and hiss on the 's' and articulate the 'p' really hard. If it doesn't work, then too bad, I tried. Later.
