porting my maf and tb
factory freaks dyno in the 335-340 range. 350+ range is stock Z06 territory.
sensor and your port-job is unique so there's no way
to get an accurate recalibration into the PCM, short
of blowing a lot time and/or money in tuning.
I would avoid any aftermarket MAF as well as advising
not to port the stocker. If you aren't able to tune then
you are going to be worse off. The only thing worse
than screwing up the MAF yourself, is paying $399 for
somebody else to screw one up for you. Er, I mean,
"calibrate for cold air induction".
If you want to get rid of the screen, that's another
matter. Opinions vary there too. But it seems to work
out for most people. If you got a cheap junkyard
MAF you could descreen the front end off that and
just swap, having the original to go back to.
maybe i should hang out with ricers when i dyno, then my car would look fast as **** too
the dyno operator was Chuck, the guy that owns the place.
Jeez. its like a bunch of kids pissed off at the world, then they get on here and talk bad about everyone elses car. CHILL OUT. why cant you just give a thumbs up instead of putting your WORTHLESS .02 in???
ill tell you what your momma's told you. if you cant say anything nice, KEEP YOUR ******* MOUTH SHUT!!!!!!!!
now back to the actual topic. i would just hog the **** out of the TB and not **** with the MAF.
Now the 1/4 mile numbers in your sig. tell a different tale. Nice strong car running 111mph.
And like everyone else has said, leave the MAF alone.
