What would YOU do (re: exhaust)
I am re-doing my exhaust system back to a y-pipe setup. I need to fit the cats and cutouts both on the y-pipe. I also need to maintain enough ground clearence to go over speed-bumps (the main reason to re-doing the exhuast).
Here are my two options:
1) Buy 3" ORY from TSP and try to fit the carsound cats and cutouts on it.
2) Have local exhaust shop custom fab a 2.5" y-pipe with cats and cutouts.
Basically, I don't really mind if the y-pipe is 2.5" and a little restrictive. If I want any power, I will open the cutouts. I am leaning towards option two right now. The problem with #1 is that TSP doesnt have any finalized pics of their y-pipe, and I don't even know if cats and cutouts will fit without hacking it to bits.
If ANYONE has any insight on this that would be great. Thanks!
The problem here comes the drivers side. I can gurantee that the cat is gonna be really low on the drivers side and its gonna catch everything. Since this is gonna cost quite a bit anyways.
This is a way that it may work. You should have flanges welded onto both the cats and the cutouts. Make them interchangable.
Just an idea.
I dont like cats. They eat more power than people realize and they are not cheap. Plus they have been known to fail. Are you getting cats for a sniff test or for visual inspection?
Here's what I'm thinking... Pacesetter headers, shortened and flanged into dual 3" cutouts(flanged), then 3" to 2.5" reducers, into 2.5" Carsound cats, into Magnaflow Y-collector, and then into 3" Dynomax I-pipe. I will have some pipe off the cutout to quiet it down a tad and to get the 16-20" I need.
If it was my car, Id keep the macs and weld up a pair of 3" cats and use the 2.5" ypipe with flowmaster collector and run it through a loudmouth catback. I heard a stock camaro with a loudmouth. I was amazed at how good it sounded.
Anyways, youre idea will definitly work and give you 15hp over my idea. Its just too complicated for my tastes. Its your car so good luck.
Nothing would scare the **** out of someone like open headers
Dan
up and move to a different state. Then get an ORY and put cutouts on those
Just my .75 cents
Good luck though
Just my .75 cents
Good luck though
. Its such a rediculous law about the cats. A small fine would be ok, but 20 g's is a little excessive.
