Oil Press. Gauge Install
Are you talking about the same thing that we are? We drilled a hole and installed the sender. It's about 2" long total, and only 1/4 is exposed to connect your wire to it..
This picture shows a water temp sender installed into the proper adapter. The oil temp sender looks the same minus the metric adapter. Pretty small little unit.
I prefer to have an oil pressure reading from the highest point possible in the engine, and the factory location accomplishes this nicely.
steve
There is a place on the 'net called Autobarn which sells a set of brass adapters to do what you need... http://www.autobarn.net/eqoilpreselt.html
Thats good to know. I was planning on putting mine in the port down by the oil filter. If I can use the one behind the intake then that would be even better!
Brad
I tapped into the cover, installed a length of steel braided line and placed the sender over and away from teh headers.
What parts were required to do this? This idea sounds totally doable, great idea! What about tapping into the stock sender for signal? Would that work?
The rest of the necessary fittings came with the Autometer guage.
I attached the sender to the inside frame rail, close to the fuel lines.
The "cover" I have is actually an adaptor I bought from LG motorsports that allows me to run the oil through a cooler.
But the factory cover should be plenty of meat.
If you look on the top of the water pump, there is a flat area. I drilled and tapped there for a water temp sender. And where the oil level sensor is in the pan, I adapted that opening for oil temperature.
