View Poll Results: Which is Better?
Ram Air Hood
5
12.20%
Cold Air Induction Kit
23
56.10%
Both together
9
21.95%
What is induction?
4
9.76%
Voters: 41. You may not vote on this poll
SSRA or Induction Kit(FIPK)?
The ram air hood is not going to gain you any HP. You need to be traveling at some seriously high speeds to use the "ram air" - it does however give you some colder air. If you use the "Ultra-Z" hood with an open element, you might see some "ram-air" gains.
SSU's Drunk Typing Whore
I got the SSRA and love it, a little overpriced for a few pieces of plastic, but it works great, just be careful parking it and going down curbs, I have ripped mine off twice now. The SS ram air hood is for appearance only, I dont know about the Ultra Z hood I guess it will give you a little gain but not alot.
[QUOTE=9camaross8]The SS ram air hood is for appearance only,[QUOTE]
It does bring air around to the front of the lid - more than a Z28, but like I said, probably more cold air than ram air.
[QUOTE='02 SLP#686][QUOTE=9camaross8]The SS ram air hood is for appearance only,
It does bring air around to the front of the lid - more than a Z28, but like I said, probably more cold air than ram air. With some intake modifications you could make the route more direct. It should be plenty sufficient for "ram" air effect.
I dont mean to hi-jack your post but has anyone modified the ssra in a way that it does not block off the radiator as much. My car ran 10-20' warmer with it. I did the FRA and i am kicking myself that i did....warm air into engine not good. i have come up with a few ideas putting to use those 2 giant holes that we have in our noses (camaro's) but it require a hell of alot of cutting to do it....but seems to be the most direct and able to bring in the same amount of air as say the ssra with out having a scoop under the car that i dont think looks all that great. Just shootin out some ideas.
Paul
Paul
Paul
Paul
The FRA just allows all of that nice warm heat from the radiator to travel upward into your engine and increase the intake temp. The dual snorkel intake you mention has been done before and IMO looks cheesy with giant heater or AC metal ducting under the hood. Also keep in mind the area directly under the nose by the air dam is high pressure and will force more air into the engine compared to the front grille area. I personally like the look the SSRA which is reminiscent of the Olds 442 dual snorkels from the 60's muscle car.
I would save your time on something better spent and just get the SSRA, it drops right in. My 02.
I can tell you the Ultra Z Hood does nothing. For example, here's a test I did at the drag strip. I made two passes with the stock lower air box cut for FRA. Then I swapped on a WS6 lower air box uncut and made four passes. The incoming air came from the opening in the Ultra Z hood. Then I put the stock lower air box back on and made two more passes. The results? The WS6 lower air box and Ultra Z set up resulted in .03~.04 faster sixty-foot times but .05~.15 slower ET's and trap speeds were down about 1.5 mph.
My theory is that the FRA works better than the Ultra Z ram air at moving speeds. But while sitting at the starting line the Ultra Z ram air works a little better the first sixty feet or so because it isn't breathing in warm air from the engine. My guess is that a SSRA kit would give you the best of both worlds. I am going to buy one and test my theory. I will let you know how it goes. Until then, I'll keep using my FRA set up.
isnt the ssra2 the same thing as the ssra, just made of plastic insteal of sheet metal? if so, why wouldn't you have to worry about scraping it on curbs....unless its positioned differently or something.
since the ssra2 is only the first half of the ssra, does it make less hp? also where can i get the ssra2? ive only seen the ssra on websites. hey sponsors, feel free to reply with sales on the ssra2 if you have it
I have the FTA style but it was made by a different company, then I have the austin scoop extension.
1. I painted it black and it blends in withe the airdam, most people don't even see it from the front.
2. It's all sheet metal, and does not even get warm, at all. Always feels like cold metal even when idling for 30min.
3. My car ran the same temp beore and after install.
4. Picked up 2mph at track.
When I put this on I setup a 70MPH leaf blower aimed directly at the airdam about 10 feet infront of the car. first I tried the free mod and turned on the blower and about 15-20% of the air from the blower was coming up to where the filter would be.
Then I used the FTRA "style" and about 45% was coming through.
Then the whole SSRA "style" and about 90-95% was coming up to the filter area.
About the SS hood. My friend has an SS with the lid sealed to the hood and you can put a receipt or small paper on the hood infront of the scoop openeing and when you rev it, it sucks it up onto the grill. So it is functional. Yes the air is traveling through the warm hood and all, but it's cooler than the air under the hood. It may not have much of a ramming affect, but cooler air yes.
