Need help removing exhaust tips from old exhaust
Hey guys, I recently switched from my LM with CME tips to a Hooker Cat Back. My problem is I can't seem to get the damn tips out of the old pipes!
I've hacked off the 90* elbows, but it looks like the clamp actually bent the pipe around the tips and left an indentation in it. No matter how much I turn and pull, I can't get them off.
Any advice?
Thanks in advance
Matt
Any advice?
Thanks in advance
Matt
I had the same issue. I used a dremel with a "cutoff" wheel and basically cut a couple of 2" long grooves longitudinally on two sides of the outer pipe. You can then twist a screwdriver in the groove to open up and loosen the outer pipe. I have used this method several times and it works for me. Of course the outer pipe is now scrap.
Originally Posted by jimmyblue
I would sure like to know how you get them off, if you do.
I tried like hell but no budge. I was not prepared to introduce
them to Mr. Sawzall....
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I banged on those bastards so much that I could barely grip the mallet after about a half hour.
By the way jimmyblue, by hacking off the 90* elbows, I meant where they connected to the exhaust, not the tips. I tried like hell to save them, but after hammering and bending and prying and cursing, they became all deformed.
