ypipe with single muffler dumped before axle?
Just wondering if anyone has a setup like this. I've heard sound clips of this on ls1sounds.com but that doesn't give it any justice. http://www.ls1sounds.com/custom.htm
LTs, no cats, 3" ypipe, single muffler dumped.
1)Is it raspy during acceleration? Raspy like the loud-mouth with LTs & no cats which sounds really gay.
2)How does it sound at idle, wot, & highway speed?
3)Performance?
4)Would you recommend this to anyone?
5)Which muffler would you use with this setup?
-Thanks
3)Performance?
-Thanks
3)Performance?
-Thanks
3)Performance?
-Thanks
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I have seen one car like that, it had a magnaflow as well, it did hang low though, im not sure where you could hang a full size muffler down there and have good clearence in that area.
i am doing that sorta, i am welding in a bullet and a QTP electric cuout after the bullet in the I pipe and leaving the stock exhaust on so it is still qiuet when i want it to be the bullet should take care of the rasp
i will let you guys know how it sounds after the headers and cam get on it
Pics seem to work now. I've been thinking of doing the same thing myself. I really need to get rid of my 2.5" duals and I really don't want to spend the money to build a good all around 3" system with dual cutouts. I think I might just pick up a cheap 3" y-pipe, 2 cutouts, and a 24" Sweet Thunder muffler. Seems like it would be a light and simple set up. I'm just not sure how the car will sound, the 24" Sweet Thunder should keep things under control but I'm really not sure. I'll also be able to run an extreme torque arm which is a huge plus for me.
Originally Posted by Birdie2000
If you're gonna dump it under the car anyways, why not use true duals?
How about this:
right after the Y, split the 3" pipe back into two 2.5" pipes and run both bullets down the passenger side. The Back to back Y pipes will function similarly to a siamesed X pipe. Its a cheap way to do true duals for not much more money than what youre already looking at.
-T
-T
If you're gonna do that, just buy a Dr. Gas X-pipe with 3" in and 2.5" out. It'll take up the same if not less room, and will be cheaper. Those Flowmaster Y's are like $60 a piece last I remember.
OKAY, ive prolly put more thought into this then anyone nad posted many questions in here already.. i have a cutout on the end of my ypipe and i am about to replace it with a bullet or something similar and a turndown.. i have macs and ory.. i figure it will save me money this way and i can sale my catback to easily make up for the cost of bullet/turndown, vs duals which can get expensive fairly easily... i figure it will flow as good as a open cutout since the muffler is a straight thru.
hey hwo hard do u think it would be to weld a x in place of the y connector and run two bullets taht way? it would still be pretty cheap?! anyone done this with a mac y?
If anything, maybe put a merge collector at the end of the Y to try and get some more flow out of it.
Originally Posted by GM Muscle
As for home made X pipes, if your looking to make really good power they are not up to the task. Believe me, I have one.
