QTP (1 7/8s) Header guys inside
Old Feb 11, 2005 | 11:03 AM
mattr228's Avatar
Default QTP (1 7/8s) Header guys inside
Im looking at purchasing some QTP 1 7/8s headers was wondering about how well these fit & ease of installation. Ive did a few searches and have come across one problem resulting in having to grind down the steering nuckel for it to clear the #1 primary. Has anyone else had problems with installation of these headers and can this be done without a lift? (to save a few extra $$$)
Thanks,
Matt
Old Feb 11, 2005 | 11:59 AM
Durien's Avatar
the word is that QTPs have the best fitment... mine fit like a glove.. i run the HVM race headers from QTP
Old Feb 11, 2005 | 02:22 PM
35thls1ss19's Avatar
i have never heard that before.... and mine fit perfect and took less then 3hrs install
Old Feb 11, 2005 | 07:45 PM
Onyx LS1's Avatar
it depends on the year of your car, most steering shafts will clear. mine (2000) didn't, they probably switched in the middle of the year also.
you can pull out the shaft without a lift.
Old Feb 11, 2005 | 07:48 PM
Harley-Davidson88's Avatar
Just curious...but why the 1-7/8 over the 1-3/4?
Old Feb 11, 2005 | 07:50 PM
02WS6Bird's Avatar
i assume he plans on doing some work on the bottom end or has some MAJOR valve train modifications soon to come-1 7/8" would be overkill on stock valvetrain i think
Old Feb 11, 2005 | 08:14 PM
mattr228's Avatar
It will be overkill for about a month or/ so after I get them, till I can port myself some heads & choose a cam that best fits what I want for my ls1.
Onyx LS1 , are you saying the header install can be done w/o a lift?
Thanks for the replies!
-Matt
Old Feb 11, 2005 | 08:19 PM
GT Griller's Avatar
Did my header install with out a lift. Put the front of the car on jackstands and got it done.
Old Feb 11, 2005 | 09:53 PM
02WS6Bird's Avatar
yeah headers can be installed without a lift-its patience thats the key and you jsut wanna get it off the ground enough to slide the headers right in theree
Old Feb 12, 2005 | 06:00 PM
Time2Kill's Avatar
MASS seller approved
QTP's fit great. I'm running the 1 7/8s on my car, only thing I had to remove to get them installed was the starter and the oil filter. Other than that, they slid right in (using BMR K-Member, stock they might not). I even left the spark plugs in
