Help: torque specs for header bolts ?
Old Feb 19, 2005 | 03:45 PM
TheBowtieboy's Avatar
Default Help: torque specs for header bolts ?
What is the torque spec for aftermarket header bolts ?
......and sequence.
Old Feb 19, 2005 | 04:08 PM
Blue02Ws6's Avatar
18ft lbs. inside out when you torque them.
Old Feb 19, 2005 | 04:14 PM
SgtB's Avatar
11 lb ft the first run then 18 the second pass
Thanks !
Old Feb 20, 2005 | 10:07 AM
shep28's Avatar
good luck trying to get a torque wrench in there
Old Feb 20, 2005 | 10:47 AM
jerflash's Avatar
dude its not easy to get a torque wrench inthere thats why i dont use one on the headers
use your judgement....tight but not very tight sould be fine...dont wana bend the flanges
i have takend my headers off and put them on meny times and have no sealin problems
what aftermarket bolts are you using?
stocks are the best if you ask me
Old Feb 20, 2005 | 11:40 AM
Blue02Ws6's Avatar
yeah hand tight is fine, and the 11ft/lbs first torque is totally unnessesary. Some people just want torque specs on everything though.
Old Feb 20, 2005 | 12:03 PM
cyphur's Avatar
i'm w/jerflash. use your best judgement, don't go too far cuz breakin a bolt off in the block sucks hard ***. good and tight and they won't go anywhere.
Old Feb 20, 2005 | 08:19 PM
Thanks for all the replies.
Actually, the driver's side wasn't that hard with a Craftsman 10-75 torque wrench; passenger side was a little more difficult.
......just took different socket configurations to get to them all.
