Catch can
Old Feb 22, 2005 | 12:39 PM
Impuls3's Avatar
Default Catch can
Alright before u flame me, i already searched for awhile on this and cant seem to find what im looking for. so does anyone know where i can get a catch can for my 00 z and my buddies 00 TA? I have heard they r easy to make also; so whatever works really, ill buy one or make one dont matter.
Any help is appreciated...ty.
Old Feb 22, 2005 | 12:56 PM
01 Red WS6's Avatar
http://www.accmachtech.com/
They are a sponsor too>>
Old Feb 22, 2005 | 12:59 PM
Impuls3's Avatar
Appreciate the find...holy smokes though $90...dindt realize they were that expensive. Those pieces do look really nice though.
Old Feb 22, 2005 | 04:11 PM
Impuls3's Avatar
2 t t
Old Feb 22, 2005 | 04:25 PM
jrp's Avatar
jrp
SN95 Director
how did you search and not come across AMW
http://www.freewebz.com/soslo/foreman_oilcatch.htm
Old Feb 22, 2005 | 04:43 PM
Impuls3's Avatar
sry man just didnt see it i guess...ty for the link though.
Old Feb 22, 2005 | 05:38 PM
Durien's Avatar
AMW user here... its a nice piece
Old Feb 22, 2005 | 05:39 PM
slowscott's Avatar
On a related note; what is the best way to mount an AMW catch can on a ls1 with egr? AMW says the bracket they sell is only for non egr cars.
Old Feb 22, 2005 | 07:16 PM
M6HuggerSS's Avatar
AMW.... hers mine....
Old Feb 22, 2005 | 09:10 PM
Martingale's Avatar
I just mounted mine right in front of the power steering pulley. I just drilled into the firm plastic stuff surrounding the radiator. It's a great location...doesn't get too close to the pulley (about an inch clear) and is a great place to access it to drain it.
Old Feb 22, 2005 | 09:18 PM
jimmyblue's Avatar
Moderator
I use a little $1.99 plastic fuel filter, the kind that has
inlet and outlet on top and the filter in a sump. It looks
a little shade-tree and hasn't caught anything much (I
don't seem to use any oil) but you can't beat the $.
If you painted it black it would disappear.
Old Feb 22, 2005 | 09:19 PM
Third Gear's Avatar
Thumbs up
Not just does the AMW piece look good... it works well too.
Mine is mounted next to the A/C dryer... where traction control normally goes, I'm lucky my car came from the factory with no traction control.
Old Feb 23, 2005 | 02:56 AM
Martingale's Avatar
I have heard this method can alter crankcase pressure and that over time it can lead to reduced ring seal and blow by. Can anyone confirm this?
Old Feb 23, 2005 | 08:06 AM
jimmyblue's Avatar
Moderator
The PCV valve is a flow-limiter anyway. Not to mention all the
hose. If you have substantial blow-by then it will be overwhelmed
and crankcase pressure will rise, regardless. PCV is another
emissions widget that works at low throttle, fine, but at high
cylinder pressures and high blowby, fugeddit.
I figure those little filters can flow well more than the PCV valve
itself will allow. Not to say there aren't "better" catch-cans
but none cheaper. If you draw a lot of oil though, I'd go for
something bigger. I put mine on as an experiment and just
left it be until it needs emptying. Then I'll put on those
compressed-air oil separators I have around here somewhere.
Old Feb 23, 2005 | 08:41 AM
2ScoopsTa's Avatar
damn i wonder if this is something that i should look into....hm.. sounds interesting. ...
