Is a cutout worth it?
Old Mar 5, 2005 | 12:59 PM
tdrumm's Avatar
Default Is a cutout worth it?
Will I actually see a performance gain from installing a cut out or just the loudness? My exhaust setup is longtubes, cats still in place and functioning and a Magnaflow cat-back.
Thanks
Old Mar 5, 2005 | 01:32 PM
blind527's Avatar
I'm pretty sure cutouts are good for an additional 5-10 hp.
Old Mar 5, 2005 | 01:42 PM
The Professor's Avatar
i was just thinking about asking the same thing. more specifically, is the QTEC Y pipe (with dual electronic cut outs) worth it. it's about twice as much as other Y pipes out there.
Old Mar 5, 2005 | 02:09 PM
LS1LT1's Avatar
Yes, they are, even more in some cases.
Yes, either the QTEC Y pipe or even just the QTEC cut out in the normal I pipe location is a HUGE convenience and there are definitely gains to be had.
www.quicktimeperformance.com
Old Mar 5, 2005 | 02:46 PM
XtinctHawk02's Avatar
All the cut-out does is by-pass the muffler.
You will notice a difference.
I have the cut-out on mine, and like it alot!
header's and ory are on the way too
Old Mar 5, 2005 | 02:50 PM
freakynipples69's Avatar
It's worth it just for the sound alone.
Old Mar 5, 2005 | 06:16 PM
mike c.'s Avatar
i gained 9hp from my q-tec cutout.
Old Mar 5, 2005 | 06:54 PM
Flawless02SS's Avatar
Is it worth it? HELL YEAH I love my dual MPP2's !!!!!
Old Mar 5, 2005 | 09:03 PM
Durien's Avatar
hell yea ....cutouts rule... i got the QTEC and love it!
Old Mar 5, 2005 | 10:06 PM
Joker # 9's Avatar
Yes a cut out is worth it, I went through 3 Q-techs before I gave up on them and just use the good old lay on your back to open it up method. If I could do it all over again I would just get the $20 manual open/close cut out.
Old Mar 6, 2005 | 12:02 AM
SDB's Avatar
SDB
I liked mine, went to a different exhaust and may not need one now...it only gets rid of about 35% of exhuast flow when placed typically in the rear of Y pipe prior to catback (per kooks)...I noticed a lot of exhaust coming through stock rear exhaust when open...lots louder and definately a difference on the bottle!
SDB
Old Mar 6, 2005 | 12:50 AM
LS1s R US's Avatar
Yes it is it will always be there unless ya knock it off. And ya can open and close it at will! What even the mood.Shoot ya can even go to the track and do back to back runs one open and one closed and see the difference if none ya got a good noise maker!
Old Mar 6, 2005 | 02:20 AM
ncd1966's Avatar
i have my cutout after the axle and i pickup a tenth in the quarter with it open not a whole lot but every tenth helps
Old Mar 6, 2005 | 03:35 AM
Judd's Avatar
I gained 5 hp open vs closed with my cut-out that is located right in front of the muffler. You might gain a smidge more if your cut-out is in the I pipe, just be harder to get to. Mine cost me something like 15-20 bucks and about 3-4 hours of cutting, grinding and welding,,,,, five hp for 20 bucks.
Old Mar 6, 2005 | 04:07 AM
d james's Avatar
well after my previous car with all bolt ons and cam and true duals I was very irritated with the sound always droning. I loved it when I wanted lots of noise, but most of the time cruising I wanted to hear my stereo loud and clear but couldn't becuae it was always loud. Now with my current car I will not put true duals on and I have installed a cutout, and its much better. I can turn of the volume at will, sometimes I like to hear it with the stereo jamming other times without the stereo and other times I just want zero noise, so with the stock exhaust i have the best of both worlds. I would never do anything else but the electric cutout its much more fun. I really don't notice any real difference with it open, just louder, but its still worth the money. Of course it does make a difference, but the 10 or so horsepower is hard to feel, but every little bit helps. Mine seems to run perfectly as well-no problems.
Old Mar 6, 2005 | 04:17 AM
Fahad's Avatar
Cutout it's the best one of Borla catback and X-pip. Cutout will be better if you put it closer to the rear end. it's so easy to see 5-10 rwhp after the cutout and the right place.
Old Mar 6, 2005 | 08:44 PM
blind527's Avatar
I'm putting it on the i pipe just before the axle. How much would it be to have this installed by a shop?
Old Mar 6, 2005 | 09:05 PM
mrr23's Avatar
been there, done that, and got rid of it. if you are doing it for the sound. great. as one guy said, he gained a tenth. i gained squat for the 1/4 mile. then i put the bassani tru-dual on and gained .3 and 3 mph. stock vs open was same day back to back.
This is with 200 n2o.
distance ---stock ----- cutout ------ Bassani
60ft ------ 1.987 ------ 2.074 ------ 1.969
1/8 ------- 7.902 ------ 7.912 ------ 7.739
mph ------ 93.20 ------ 93.97 ------ 98.60
1/4 ------ 12.102 ---- 12.080 ------ 11.814
mph ------ 117.12 ---- 118.06 ----- 121.35
i did gain 11/13 on the dyno. but that was AFTER 3200 rpms. dynoing didn't show what happened UNDER 3000rpms.
Old Mar 7, 2005 | 02:09 AM
TNormZ28's Avatar
If your muffler sucks then you will gain some hp and cut your e/t, but if it is a good flowing muffler like the Hooker Aerochamber then it's not worth the trouble.
Old Mar 7, 2005 | 05:48 AM
tdrumm's Avatar
Well, I do kind of want it for the sound, and for $35 it couldn't hurt to throw a manual one in there and see how I like it before committing to a QTP. Next time I have the thing up in the air I'll look for a place to put it under there (I have a truck BTW).
