Overheating problem! Need help asap!
Old Mar 15, 2005 | 07:41 PM
CMKworm's Avatar
Exclamation Overheating problem! Need help asap!
Ok ever since I got my procharger put on with my fmic my car just randomly gets hot as hell and then it goes away. I checked coolant, use purple ice, have a new ati fan, and I just put my thermostat in boiling water and it opened up. It's only been in the 40's too. What's going on and what should I do?
Old Mar 15, 2005 | 08:04 PM
DravenMyers's Avatar
You should read the temp with a scaner ro use a temp gun to verify the temp on the gauge it might be a bad gauge.
Old Mar 15, 2005 | 08:10 PM
jimmyblue's Avatar
Moderator
I have seen intermittent ECT sensor connection (at the sender)
make for some insane PCM spark and fuel behavior. Might want
to clean, see if you can tighten up the spring-clip.
Old Mar 15, 2005 | 08:49 PM
CMKworm's Avatar
Where exactly are those things at? To check the guage do I have to pull the part behind the steering wheel out?
Old Mar 15, 2005 | 09:44 PM
Inspector12's Avatar
TT-TECH Veteran
There were a number of people that had overheating problems with there ATI kits in the past do a search and see what they did to fix it etc...
Old Mar 15, 2005 | 11:38 PM
I dont think your gauge is broken what I am trying to say is to confirm the reading on it to berify that it is overheating
Old Mar 15, 2005 | 11:41 PM
CMKworm's Avatar
True, it's weird b/c I never had a problem until I put this thing on!
Old Mar 15, 2005 | 11:43 PM
white2001s10's Avatar
I'd take the fmic off to see if the problem goes away.
Old Mar 16, 2005 | 09:21 PM
chris01ws6's Avatar
my brother had an air pocket in the coolant and would overheat, did you just change it??????????????
Old Mar 17, 2005 | 12:27 AM
CMKworm's Avatar
Not changed recently.
