MAF Screen
Manifold pressure @ engine airflow = power. But the
screen also serves a purpose; it forces the air into a
more evenly distributed flow across the face, which
the hot-wire MAF depends upon for accuracy in its
reading. If your intake tract produces a biased airflow
(like for example a curve will "crowd" the air to the
outside) a descreened MAF can have distorted airflow
readings (as frequency) relative to true airflow. This
can bend the mixture lean or rich.
Since F-bodies have a relatively straight intake tract
this seems to not be much of a problem and people do
it all the time. Some folks notice things like softer A4
shifts (bad) or some mixture drift.
The right answer is to get a junker, LT1 or LS1 F-body
MAF and pop the screen off -that-. The ends are
swappable and you can go back and forth as you please.
Do not grind on them or the plastic piece. Just the screen
and maybe epoxy-fill the divot-ring in the snout if you
are an obsessive sort.
At shop-vac flow rates I found the screened MAF an
equal restriction to the stock airlid, in the pressure drop
produced. So it's worth doing if you can avoid or tolerate
any metering changes. If you have a M6 car then there
is very little likelihood of a downside. The A4s have
another thing to worry about.
I did mine it's fine but I didn't do anything else but a slight internal polish I have smoth bellows and slp lid no powere adder.
What gives?
Alan
Alan
<--- Descreened and lovin' it.
