exhaust manifold bolts torque-to-yield?
Old Mar 31, 2005 | 01:47 PM
kilmor's Avatar
Default exhaust manifold bolts torque-to-yield?
title says it all, are the gm exhaust manifold bolts torque to yield?
I thought I read something about this but cant seem to find it anywhere.
If they arent, are the bottom of the bolts supposed to look like they're missing about 3-4 threads?
Old Mar 31, 2005 | 01:52 PM
elite22xl's Avatar
yea i just got 5 more bolts from a dealer and the head size is different too
Old Mar 31, 2005 | 02:01 PM
Steve Burger's Avatar
LS1TECH Sponsor
I have reused them a number of times. I have never heard or read that they are TTY.
Old Apr 1, 2005 | 07:45 AM
black99ta's Avatar
Yielding a steel bolt when threading it into aluminum heads? I really doubt they are TTY.
Old Apr 1, 2005 | 07:52 AM
NHRATA01's Avatar
They're not TTY, and they only take about 18 ft*lbs if memory serves.
Old Apr 1, 2005 | 08:24 AM
bowtieman81's Avatar
They are NOT torque to yield bolts! Don't even try this, you will tear the threads right out of your heads (steel = higher tensile strength than aluminum). The torque spec for them is 18 ft-lbs, as mentioned above.
Old Apr 1, 2005 | 09:45 AM
Unaffliated Racing's Avatar
I will agree..they are not TTY bolts. The only problem I see is a couple of ya'll are saying " don't do it..it's a steel bolt going into aluminum"...ummm what do you think the head bolts are and the block?lol
Old Apr 2, 2005 | 12:27 AM
00ls1's Avatar
Possible Scammer - Buyer Beware - Issues Unresolved
the block is aluminum, good try though
Old Apr 2, 2005 | 02:19 AM
Schantin's Avatar
Good Lord, no they are NOT torque to yield! As mentioned above the torque is 18ft/lbs (It's actually 15-18ft/lbs). You will DEFINETLY jack up the thread pattern in the head by doing much more torque than this.
Schantin
2002 Camaro Z28 M6
