Which true dual setup will be easiest to make work?
Old Apr 4, 2005 | 10:59 PM
Stang_Killa's Avatar
Default Which true dual setup will be easiest to make work?
Which is better lanes or TSP true duals?? Whic is eaiser to make fit a 1998 z28? Wondering which one to get need help?
Old Apr 4, 2005 | 11:02 PM
snake charmer's Avatar
The TSP is popular system. You might be able to get a better deal by going custom with some good headers. Really a matter of how much you are wanting to spend on the system.
Old Apr 4, 2005 | 11:18 PM
Z-286speed's Avatar
I have the TSP on a 99, and they fit great, just depends on the money like snake said.
Old Apr 4, 2005 | 11:22 PM
Camaro99SS's Avatar
I just got Lane's kit, and it comes with quality hangers and everything you need to bolt it on, and it's custom built and welded, no adjusting and tinkering with it like the TSP. Mine fit like a glove and at most I lost maybe an inch of ground clearance where the sagging stock Y pipe used to be mainly because the pipe isn't crushed like the stocker and is bigger. I highly recommend his kit. Plus Lane uses a Dr. Gas X pipe which TSP doesn't. Lane's kit is $495 plus shipping, and since TSP now charges for shipping, there's really not much of a cost advantage anymore with the TSP. Lane is a great guy and very knowledgeable.
But if you decide against Lane's kit, I would just get the universal kit from Summit which will be around $200 when you add in mufflers. It's very similar to TSP's setup and will fit Jet-Hot headers without any changes, and fit Pacesetters with a little tweaking by a shop. There is a huge thread over on www.camaroz28.com in the LT1 section started by "Poorman" that covers this kit. Here's the link. http://web.camaross.com/forums/showt...ght=true+duals
Jason
Old Apr 4, 2005 | 11:28 PM
LS1Maniac's Avatar
Any system you buy will require "tweaking" to get it to fit right. It's just part of the process of bolting on an exhaust system. You can't just slap it together and have it magically fit perfectly.
As far as which is better.. I think it comes down to personal preferance. Both kits are very high quality. I would buy whichever one you can afford to buy. TSP costs $419 and the Lanes's cost $495.
Old Apr 4, 2005 | 11:34 PM
matts22's Avatar
I've got Lane's awaiting install at my house (in May).
Old Apr 5, 2005 | 03:17 PM
Camaro99SS's Avatar
My kit from Lane's bolted right up with no tweaking. It is possible.
Jason
Old Apr 5, 2005 | 03:29 PM
Keenov's Avatar
I got the TSP kit and it fits perfect. Though it came with 700 pieces. Any moron should be able to figure out how to put it together though.
Old Apr 5, 2005 | 03:58 PM
LS1Maniac's Avatar
Jason
There is no difference in the way Lane's kit and TSP's kit bolt up. They both have pipes that slide into one another and are held on by clamps. The only difference between the two are the materials used. There's nothing that makes either kit easier to set up than the other. It just comes down to whether or not you want to pay the extra 80 bucks for a Dr-Gas X-Pipe or if you're happy with the ones TSP makes.
Old Apr 5, 2005 | 04:17 PM
4.6gt-2-ls1ta's Avatar
Lane's kit doesn't come in pieces that you clamp together his comes already welded and tucks up much higher than the bolt together TSP ones I have seen. Mine is no lower than my previous Y setup and in some places is actually higher. I would suggest Lane's, but it's your money and your choice.
Old Apr 5, 2005 | 06:15 PM
thanks guys, would they bolt up to a stock manifold?
Old Apr 5, 2005 | 07:09 PM
LS1Maniac's Avatar
Nope. You need long tube headers. Lanes does custom exhaust systems though and I'm sure they could make you a kit for stock manifolds for the right amount of money.
Old Apr 5, 2005 | 07:42 PM
matts22's Avatar
You are obviously very misinformed by looking at your last two posts.
Lane makes duals on a set-by-set basis. I am about 95% certain that it is the same price for manifolds or headers.
His kit ships as a completely welded system and tucks up very well from what I hear. You just tell him what headers you have, and he has a jig to make each one of them fit up to those headers (most brands).
You act like Lane's setup is the same as TSP only more expensive because he uses different materials. Well, this isn't totally the case, as explained in my post.
Old Apr 5, 2005 | 09:22 PM
Camaro99SS's Avatar
Most with the TSP including JRP had to spend some time adjusting it to get the most clearance. You can just slap it on there but you'll probably scrape everywhere too. Also, Lane's uses much better clamps for the collectors than the standard band clamps the TSP uses and other catbacks use. I used to hold the same opinion as you until I looked more into the 2 kits and talked to both places. Once I saw Lane's kit when it came, I never thought twice about saving $ and going with TSP. It's very high quality with good clean welds and tucks up well. It is a little low for my tastes just before the X but only because the pipes aren't crushed and they're bigger than the stock Y. I should have pics up by Thursday of my stock exhaust and my setup now.
Jason
Old Apr 5, 2005 | 09:25 PM
Camaro99SS's Avatar
oops i double posted
Old Apr 5, 2005 | 10:49 PM
destroyerSS's Avatar
I went with TSP dual's for a few reasons
1 great customer service
2 great products
3 THEY PAY TO HELP KEEP THIS SITE GOING
Old Apr 5, 2005 | 11:30 PM
matts22's Avatar
I agree with that...TSP has great customer service and I have bought stuff from them in the past. I would also agree that supporting sponsors is important. However, I'm going to go with which product I like best. Lane has gone above and beyond any amount of customer service I could have ever imagined. If you don't believe me, I have close to 10 pages of copy and pasted saved text from talking to him on AIM. Yes, it would be nice if he was a sponsor. But that's not going to stop me from buying his product. I have yet to hear ANY complaints on his duals. That's a big reason I went with them.
Old Apr 6, 2005 | 06:44 PM
mrr23's Avatar
the bassani tru-duals are made to fit stock manifolds and cats for 98-02 f-bodies. click the links in my sig to see pics of the system and installation on the cars.
Old Apr 6, 2005 | 06:53 PM
aaronc777's Avatar
Do you need to have headers to run a true dual?? I cannot afford both at this time, could I still put true duals on and add headers later??
Old Apr 6, 2005 | 06:57 PM
mrr23's Avatar
no. the bassani hooks to the factory cats and runs all the way out the back. i have it that way on my 00 formula. http://www.stealthram.com/bassanidualexhaust.htm then afterwards, all you would need to do is make some pipe to fit from whatever headers you use to the x-pipe as i did on the wife's car. same would go for the other duals out there.
