tourqe
Old May 4, 2005 | 02:52 PM
00formLs1's Avatar
Default tourqe
whats the tourqe for the header bolts?
Old May 4, 2005 | 03:17 PM
SLPSS01's Avatar
I believe it's 18ft-lbs
I just installed mine until they were good and tight.
Old May 4, 2005 | 03:57 PM
Coy's Avatar
Coy
snug, wait 200 miles, then snug again.
Old May 4, 2005 | 04:01 PM
cyphur's Avatar
yea....good and tight. i used locking header bolts.
and its "torque" not "tourqe", fyi.
Old May 4, 2005 | 04:10 PM
00formLs1's Avatar
opps i typed to fast
Old May 4, 2005 | 04:21 PM
bowtieman81's Avatar
It's 18 ft-lbs, and as said check them again after some miles to make sure they stay tight.
Old May 4, 2005 | 06:12 PM
GT Griller's Avatar
I haven't checked mine in since i put them on. Prolly like 4k miles or so. How do u know its leaking? My y-pipe leaks and it has black marks will my heads get black marks if its leaking?
Old May 4, 2005 | 06:39 PM
01TAFlyer's Avatar
I think first pass to 11ft/lbs and the second to 18ft/lbs.
And GT Griller, if you are seeing black marks on the heads, the leak will be big, and def. audibly noticeable, and if the leak is that big, it will probably be throwing your o2s off. Best way to check for leaks at the flange is the soapy water trick.
