what oil to use
Do a search, there was a real good thread about oil no to long ago.
) 0w 30. Tests show it has the best wear of any oil out there, even the mobil 1s. Do a search on a guy named Patman and you'll be amazed at what you find, this guy knows his ****. And that oil your using....i don't think anyone uses that. I was planning on running the mobil in my LS1, so I am going to sit back and see what reply's you get. I too am going to search "patman" because knowledge is better that advertizements.
Synthetics are best, but more expensive. If you've got an oil change fever then it's advisable to go with conventional oil. Synthetics will give you better protection and a cleaner engine but it will become mighty expensive if you change every 3k miles.
I have yet to be convinced that German Castrol is significantly better than Mobil1 or Amsoil. That's just me. Some swear by it. Whatever your view, it certainly can be difficult to find. So, unless you enjoy the thrill of the chase and have a lot of spare time, you may want to go with something a little more readily available.
There are a lot of threads in the forum about which oil is better, as has already been mentioned. However, without hard numbers it's only an opinion.
Don't buy Fram filters. Go with Wix, Pure One, Mobil1, K&N, or Purolator.
My $.02 worth.
Further studies:
Oil FAQ
Oil Filter Study #1
Oil Filter Study #2
Synthetic Oil Life Study
General Synthetic Oil Search
General Motor Oil Search
