High Mount AC Bracket?
Old May 11, 2005 | 11:02 PM
IMD's Avatar
IMD
Default High Mount AC Bracket?
ive seen this part on a few cars, where do i find it? mounts the AC up high.....
Old May 12, 2005 | 07:07 AM
LARRY01Z28's Avatar
hey man did you ship my pedals yet???
Old May 24, 2005 | 05:54 PM
mys10v8's Avatar
Did you get an answer to this question? I believe there is someone on this forum that published specs for a DIY AC bracket but I cannot seem to find it.
Old May 24, 2005 | 07:14 PM
IMD's Avatar
IMD
i havent gotten that answer, im looking for the bracket ive seen in some pics that has the AC mounted up just to the passenger side of the TB.
Old May 25, 2005 | 01:46 AM
bmfcamaro's Avatar
talking about the phamspeed bracket??
Old May 25, 2005 | 07:49 PM
IMD's Avatar
IMD
i dont kn ow what bracket im talking about....hence the point of this thread. does phamspeed sell a high mount AC bracket?
Old May 25, 2005 | 08:23 PM
bmfcamaro's Avatar
i believe so check out there website or the turbo thread--------------->>>>
Old May 25, 2005 | 10:13 PM
mys10v8's Avatar
Here are some examples I have collected so far. The pics show 2 different brackets. Both use the Sanden 508 compressor - a common compressor used by hotrod builders to put air in vintage cars.
The black bracket is made by:
Newman Car Creations
325 Santa Bella
Paso Robles, CA 93446 -3658 http://www.carcreationsinc.com/
$550 without compressor
$770 with compressor
The silver one is a DIY.
Others:
Street and Performance also makes one. It does not use the belt tensioner. Belt tension is maintained the old fashioned way - You have to adjust it and maintain it. This also uses the Sanden compressor. www.hotrodlane.cc
March also makes one that puts the compressor above the head, not beside it. Don't know any more on this because that would make it stick out of my hood...
I think I am going to try and duplicate the Newman bracket. It uses the stock GM tensioner.
I also have an example of a DIY alternator bracket. If anyone is interested I will re-post pics and specs...
Attached Thumbnails High Mount AC Bracket?-ac-brackets.jpg   High Mount AC Bracket?-ac-brackets-installed-2.jpg   High Mount AC Bracket?-ac-bracket-newman-small.jpg   High Mount AC Bracket?-ac-brackets-installed-small.jpg
Old Aug 8, 2005 | 02:16 PM
LS1GMCTruck's Avatar
Question When Using The Sanden 508...
Compressor...On the initial start-up of the engine, can it be run without being plumbed or completed(pressurized), to run it over to the local A-C shop? Or do we need to plumb the system & charge it up with 134-R refrigerant? Thanks, Gar
Old Aug 18, 2005 | 01:36 AM
pt67camarols1's Avatar
cab we pls see DIY bracket and some info on that. I have allso got this problem to put A/C on my 67 Camaro.
Thanks
