''I had installed my cat-back & air lid"
Here is the pic
Here is he cat-back
What is the benefit from this hosepipe? Its open, do I need to close it or keep it like this?
Here is he cat-back
Originally Posted by white02ws6
um, if you didnt have a hose going to the factory lid you need to block it off. the 01-02 cars have that hose going to the stock lid, and the 98-00 dont.
You do need to block that off though, its letting some of the air out that you want crammed into the engine.
ah well, i was close. mines a 02 so i got it. it doesnt do anything for you, and it kinda looks like crap. i am just too lazy to buy the little filter for the pump end and cap the lid.
Here is the pic
[[/IMG]
[[/IMG]
all F-bodies had the air system. its an emissions component. they removed the EGR in 01-02 b/c of the different cam that met emissions a bit easier(didn't require the EGR, started using the LS6 intake).
LS1SS4EVER, i've heard alot of complaints about that SLP scoop for warmer areas of the country, such as texas where you live. If it's causing you problems, maybe just take it out? You don't want to divert too much air from your radiator?
You can get a filter from most sponsor for that hose too.. K&N, or even an el cheapo filter from autozone or something to stick in the hose, until you remove the air system entirely.
just put a baby filter on the end of the hose! i have the slp cold air with the add on piece from fasttoys that extends it to the air dam and I am happy with it. it makes it more like a true ram air setup, just have to remember to block it off when it rains
