Clever way to keep Lid tight?
Old May 24, 2005 | 07:30 PM
MadMike's Avatar
Default Clever way to keep Lid tight?
This has been an ongoing problem with my 98 z28, i have an slp airlid w/k&n filter and smooth bellows.. Almost every time i get from point a to point b the lid has worked itself loose. The clips on the front pop right off. Anyone find a good trick to keep this sucker in place ? TIA
Old May 24, 2005 | 07:34 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Might need to trim the bellows a little bit. I had to several times, just cut off a little bit at a time until it fits in good.
Old May 25, 2005 | 01:08 AM
armkneez8's Avatar
I had that problem before but I went to Home Deot and bought some Zip tight!They look like small plastic belts located at the electrical section. Put then on the Lid clips, tie them down and ur problem solved!Enjoy!
Old May 25, 2005 | 02:06 AM
Wnts2Go10O's Avatar
duct tape?
Old May 25, 2005 | 07:14 AM
jam01's Avatar
my k&n came with a thin weatherstrip that kept everything tight
Old May 25, 2005 | 07:43 AM
shouldaboughttheZ's Avatar
I had one side always do it. I finally readjusted everything and problem was gone.
Old May 25, 2005 | 07:51 AM
rufretic's Avatar
Same thing with mine. Sometimes if you just mess around with it all a little you can get it to fit better. Try and get everything to fit together nicely before tightening any of the screws.
Old May 25, 2005 | 11:17 AM
zrated's Avatar
SAme with mine would always pop. Finally cut alittle off the bellow fits great now
Old May 25, 2005 | 11:47 AM
00Z28 Camaro's Avatar
This might sound stupid but when I did a lid I didnt put the front " tab" into the"slot " , I had the tab infront of it overhanging and I couldnt get the clips to stay on for my life . Wouldnt hurt to check I think Im the only idiot who could do that though lol
Old May 25, 2005 | 07:14 PM
WILWAXU's Avatar
Don't feel so bad, very common actually.
I'd check that first.
Old May 25, 2005 | 09:13 PM
00SS4780's Avatar
A local lady her had the same problem. She put some zip ties on it and it holds fine. She got the real small ones and just put them on to hold the clip together. Later...
Old May 25, 2005 | 09:17 PM
1QuickT-A's Avatar
I'm willing to bet that is the problem... Mine kept doing the same thing and then I realized WTF the deal was and re-adjusted everything and put it on correctly and its been fine ever since!
Old May 26, 2005 | 06:29 AM
MadMike's Avatar
lol ok then glad to hear im not the only one who's had this problem, im gonna try that now, i'll report back if im a moron or not =) thnx guys !
Old May 26, 2005 | 10:43 AM
USMARINE1108's Avatar
I did the same thing, too.
Old May 26, 2005 | 10:53 AM
dave70's Avatar
same here i had the front lip of the lid in front of the airbox instead of behind the airbox lip the clips would never stay clipped. works fine now just need to replace the poorly fitting filter
Old May 26, 2005 | 11:53 AM
LiquidFire350's Avatar
same here, my clips kept popping off, it was the front lip of the lid was on the outside of the box, just put the front lip of the lid into the box and it holds perfect, i dont even have the rubbing on the hood problem some people complain off
