LT install, how high must car be?
Old Jun 13, 2005 | 08:16 PM
SIK02SS's Avatar
Default LT install, how high must car be?
ya, i got my pacestters in today and i read somewhere a while back, cant remember where, but it said an approximate height the car must be lifted to in order to install Lt's. i thought it might be in the sticky up top, but didnt see it. can someone chime me in please? thanks
chris
Old Jun 13, 2005 | 08:35 PM
Lithium's Avatar
SSU's Drunk Typing Whore
I had the floor jack almost maxed out to get the pacesetters on the car. I did not have any blocks of wood to get it higher or anything like that, just the jack was enough for me.
Old Jun 13, 2005 | 08:59 PM
94formulabird's Avatar
I had to use some wood, but there is no exact number..just get under there and keep jacking untill its high enough. simple
Old Jun 13, 2005 | 09:06 PM
SupahRich's Avatar
I had the bottom of my tires 14"s off the ground, gave me enough clearance to get the LT's under the car and in to position so that they would slide easily in to the engine bay. The back tires were on 2 X 4's.
Old Jun 13, 2005 | 09:15 PM
SIK02SS's Avatar
so basically just take the jack up til it goes no further? sounds easy enough, i was thinking about just getting 4x4 blocks and just set all 4 wheels on em and if need be jack higher. thanks for the input
Old Jun 13, 2005 | 09:21 PM
badpewter-z's Avatar
LS1TECH Sponsor
easist way on the ground is put 4-5 2x12's under each rear tire then jack the front as high as the jack will go shouldnt be to bad after that
Old Jun 13, 2005 | 09:26 PM
jrp's Avatar
jrp
SN95 Director
just get it however high you need to to get the header it.
Old Jun 13, 2005 | 11:22 PM
Wnts2Go10O's Avatar
minimum height needed.. it really didnt take much to slide the lt's into the ss.
Old Jun 13, 2005 | 11:25 PM
USMARINE1108's Avatar
I think the height is more for comfort, than clearance. I had my wheels about 8-10 inches off the ground.
Old Jun 14, 2005 | 05:27 AM
calongo_SS's Avatar
The highest you will need to go is the height of the header standing on end. It will need to be 3-4 inches shy of that height.
Old Jun 14, 2005 | 07:28 AM
CATCH ME's Avatar
put it as high as u need to just make sure the car is safely held up and that someone can bolt up the headers when they go in. it should make life easier that way, although the pacesetter install i did was a breeze
Old Jun 14, 2005 | 08:40 AM
02blkragtopz's Avatar
When I did mine I backed the car onto the Rhino's, then I jacked the font of the car up to about 19" (Jack Stands, were set at 19") and put 'em right there on the frame behind the front wheels. Pacesetters slid in like a hot knife thru butta' I took off the front tires....................makes gettin underneath on yer back much easier.
Old Jun 14, 2005 | 08:56 AM
josh99ta's Avatar
Sold The Fun Stuff :(
I think you can get it done with around a foot, but to make it easy, to not scratch you and your headers up, maybe two feet off the ground. We had my car jacked up max with a big floor jack then heavy duty jackstands, and have PLENTY of room to work with.
Old Jun 14, 2005 | 09:46 AM
Bryan @ Speed Inc.'s Avatar
Default that's it?
man i had to grind off the little casting off the back side of the block on the driver's side, and remove the oil filter WITH the car up really high to get my flowtech's in. passenger side was just thrown in... it was a breeze. but the driver's side was hell
Old Jun 14, 2005 | 05:52 PM
platniumta's Avatar
Restricted User
It has to be at least 14" to 18" off the ground. The higher you can get it the easier it is to work on.
Old Jun 15, 2005 | 09:20 AM
DOUBT IT's Avatar
I had mine at 14 1/2 inches at the passenger side tire. That and I took the heat-shield off. Slid right in after that. This was with the rear tires on the ground, BTW.
