True Dual Owners In Here - Ground Clearance
Old Jun 15, 2005 | 08:56 AM
josh99ta's Avatar
Sold The Fun Stuff :(
Default True Dual Owners In Here - Ground Clearance
How bad off are you guys? Lets do a little survey that could be helpful for others while we're at it...
1. Which headers do you have?
2. Which dual setup do you have (piping size, mufflers, crossover pipe, dumps or over-the-axle, etc)?
3. Which springs and shocks do you have?
4. What is the lowest point on your system and how much clearance do you have?
5. Extra comments:
I'll go first...
1. Pacesetter race style long tubes
2. Texas Speed & Performance 3" TDs, Moroso Spiral Flows, dumped
3. Eibach Pro Kit w/ Bilstein shocks (25 3/4" front height, 26 3/4" rear)
4. The driver's side pipe just off the headers, the x-pipe, and the very beginning of the muffler's body are all 2" off the ground on the driver's side.
5. The springs + TDs are too low to be practical. 2" of clearance is ridiculous. These springs lowered my car quite a bit more than advertised so it has to come back up. 3" of clearance is where I draw the line. IMO, 3" TDs that aren't custom and tucked into the tunnel aren't for really low cars IMO.
Old Jun 15, 2005 | 10:27 AM
jm8881's Avatar
1. Hooker LT's
2. Custom 3" TD's with an H and bullets ended before the rear axle w/o turn downs.
3. Stock
4. The lowest point on the system is right after the drivers side header. I don't have a measurement but I've only scrapped one speed bump and it barely touched the pipe.
See the pipes under the car, plenty of room.
TD system picture. Ignore the wrapping around the mufflers, that was an attempt to reduce drone from vibration. It helped a little but wasn't worth the money for the header wrapping. Also I removed the turn downs and that almost eliminated the drone. Much better tone and sound and way easier to have a conversation now.
Old Jun 15, 2005 | 10:49 AM
GM Muscle's Avatar
My 2.5" duals clear pretty damn well. Jet Hot headers, x-pipe, and 12" bullets. And yes I do need to adjust that right side pipe and hanger, one of those things I never get around to doing.
Old Jun 15, 2005 | 12:04 PM
Y2K SS's Avatar
1. Grot LT's
2. Custom Duals with X-pipe and Flowmaster single chamber mufflers over the axles with Chrome Tips.
3. Mac lowering springs
4. Clearance almost as same as when I had a catback system.
5. My exhaust man pounded up inder the rear passenger seats and tucked the mufflers up in there. Only problem I have is that they're 3" pipes and because the car is lowered, the axles will sometimes hit the exhaust which goes over them. Looks good though.
Sorry I don't know how to do the pic thing. I got a lot of pictures.
Old Jun 15, 2005 | 12:57 PM
CATCH ME's Avatar
1: SLP longtubes (going away soon)
2: Lanes duals 2.5x w/ flo-pro twisters dumped
3: Not sure which springs, but its a 1.25 drop, stock shocks (also going soon)
4: lowest point is after the drivers side header and its about 3.75-4 inches off the ground
5: it scrapes on large speedbumps if im not careful, but then again i have SLP's on a lowered car so im a sinner but aside from that i have no problems with it. not to mention it sounds BAD ***!!!!! IMO not too loud but def. loud enough (had LM w/ ORY before so that was loud!) if i can find a pic ill put it in
Old Jun 15, 2005 | 02:54 PM
m6z's Avatar
m6z
tsp duals, prokit, stock shocks.
Old Jun 16, 2005 | 02:25 PM
DOUBT IT's Avatar
Pacesetter Race LT's
TSP Duals with Dynomax Bullets
Stock springs and shocks with rear spring isolators removed
See Pictures
On a car like mine (mainly used as daily driver/weekend warrior), that's not lowered, The clearance is great.
Attached Thumbnails True Dual Owners In Here - Ground Clearance-l1-pipe-copy.jpg   True Dual Owners In Here - Ground Clearance-bullets-copy.jpg   True Dual Owners In Here - Ground Clearance-dumps-copy.jpg
Old Jun 16, 2005 | 02:46 PM
JBIRD02's Avatar
1) JetHot headers
2) 3" Flowmaster scavenger crossover and dual exhaust kit, Flowmaster 1-chambers dumped
3) stock springs & shocks
4) 4.5" of clearance except on the driver side, just before the muffler, i had to watch out for my fuel lines, so that is my lowest point at about 4"
Old Jun 16, 2005 | 03:09 PM
Z-286speed's Avatar
1) pacesetters
2) TSP true duals, 18 inch bullets
3) stock springs
4) a can of coke all the way around(used a jack to get those tips way up there)
Old Jun 16, 2005 | 04:21 PM
blkZ28spt's Avatar
1. Jet-Hot longtubes
2. LS1 Speed custom 3" duals with dynomax bullets, dumped.
3. Stock suspension
4. The two lowest points are the very beginning of the bullet mufflers and the driver's side pipe where the floorboard is low, where the stock Y-pipe is crushed. Each location is a little under 4". For visual aid, it is only about a thumb's width away from fitting an upright 12 oz aluminum can beneath it.
5. Extra comments: badass sound.
Old Jun 16, 2005 | 06:01 PM
Camaro99SS's Avatar
Pacesetter LT's
Lane's TD's 3" dumped at axle
stock ride height
The lowest point is right after the driver's side header. I'm happy with my setup. If I scrape anywhere, it's always the front air dam, not the exhaust. Here are my pics.
http://i2.photobucket.com/albums/y6.../Picture169.jpg
http://i2.photobucket.com/albums/y6.../Picture170.jpg
http://i2.photobucket.com/albums/y6.../Picture171.jpg
Jason
Old Jun 16, 2005 | 06:34 PM
DWillTA's Avatar
1. Coated Race Style Pacesetters
2. Custom 2.5" Over Axle w/Magnaflow Tru-X crossover & 4" Round body Magnaflows
3. Stock Springs w/ Half a coil cut off and Bilstein HD's
4. The lowest point is where the pipe shoots up to go over the axle.
5. A BMR UPR bar was used for clearance. Mufflers where mounted behind the axle before the tips.
Here are some pics:
Attached Thumbnails True Dual Owners In Here - Ground Clearance-mvc-041s.jpg   True Dual Owners In Here - Ground Clearance-mvc-036s.jpg   True Dual Owners In Here - Ground Clearance-mvc-037s.jpg   True Dual Owners In Here - Ground Clearance-mvc-039s.jpg
Old Jun 16, 2005 | 06:48 PM
DWillTA's Avatar
27 1/4" measured from the ground to the highest fender point. Some more pics of ground clearance.
Attached Thumbnails True Dual Owners In Here - Ground Clearance-side-view5.jpg   True Dual Owners In Here - Ground Clearance-clearance1.jpg   True Dual Owners In Here - Ground Clearance-clearance2.jpg   True Dual Owners In Here - Ground Clearance-clearance3.jpg   True Dual Owners In Here - Ground Clearance-clearance4.jpg
Old Jun 16, 2005 | 07:09 PM
kpowr82's Avatar
Originally Posted by jm8881
1. Hooker LT's
3. Stock
Hey man, how you liking those wheels so far? I sold you those if memory serves me correct. That is a sharp looking ride dude.
Old Jun 17, 2005 | 07:50 AM
jm8881's Avatar
I loved them, I got many compliments on them. Sadly though I had to sell them a little while ago. Needed the money. Now I'm rockin the salad shooters.
Old Jun 17, 2005 | 04:15 PM
rez-t/a's Avatar
1.Coated LT pacesetters
2. 3" Speed Inc. TD race X pipe dumped before the axle
3.Stock springs and shocks
4.Lowest point right after the header driver side. 4" clearance at the lowest point!
5.Not much help from Speed Inc. If you have any questions just ask!! Looks Great for the Price so you cant beat that!!!
Old Jun 18, 2005 | 12:37 AM
jj_z28's Avatar
1. Pacesetter Longtubes
2. TSP 3" true duals w/ race bullets
3. Eibach sportlines w/ stock shocks
4. Never measured
5. I want them out the back badly.
Started my under axle setup so the turn down on pass. looks messed up.
X-pipe clearance w/ BMR adjustable torque arm
Old Jun 18, 2005 | 12:43 AM
jj_z28's Avatar
One more, bad pic but u can see the clearance is decent for sportlines.
Old Jun 18, 2005 | 01:26 AM
DONAIMIAN's Avatar
I had em and got rid of them. If I was do it all over again I would take it out the back and use oval tubing in some of the lower ground clearence places. I hated the ground clearence and the drone that came with em. Didnt care for the sound anywhere but WOT.
