Ported TB tune?
Old Jul 5, 2005 | 03:02 AM
Casperws6's Avatar
Default Ported TB tune?
i had my car dyno tuned and all, if i were to get my TB ported, would i need to retune or should i pick up on some hp just bolting it back on without a tune?
Old Jul 5, 2005 | 03:05 AM
setxws6's Avatar
No tune needed
Old Jul 5, 2005 | 06:56 PM
Casperws6's Avatar
thanks
Old Jul 6, 2005 | 10:41 AM
98A4LS1's Avatar
I had to after ported TB install.
Old Jul 6, 2005 | 02:11 PM
blue01ta's Avatar
You had to or you chose to? Just curious 'cause mine should be on it's way here.
Old Jul 7, 2005 | 06:10 AM
98A4LS1's Avatar
Good point. Chose to.
Old Jul 7, 2005 | 09:15 PM
electricz28's Avatar
If you can get a good price on the retune why not. Hell if I could I would always tweak on mine if I had the software.
Old Jul 7, 2005 | 09:23 PM
Wyckedcamaro's Avatar
i HAVE to.
My idle is ALL OVER THE PLACE and yes.. everything is good with it and no issues installing it.
It will go from 700 to 1400 when in neutral at a light.
and then back down. car just revs and stumbles and threw a code after install.
I have been driving around for about 3-4 months like this lol.
But I NEED a tune
it was an S2 Shaner on my 2001 Camaro SS
Old Jul 7, 2005 | 09:26 PM
cyphur's Avatar
if you have the software, its always a good idea to tweak it. it can net a little more power and you can always tweak the mpg(sometimes more important when its 2.25/gal). if you get it professionally tuned @ a shop, i'd wait for something much more significant before taking it for a tune/retune, even if its free(unless they don't charge for dyno time).
edit - wyckedcamaro.....that sounds more like a physical problem then a tune issue. i've ported over a dozen tb's and i've never had one do that. mine have never needed to be tuned for either to keep an idle.....when it goes all over the place like that you blew your iac sensor or you have a seal issue with the blade.
