Mac mids
Old Jul 8, 2005 | 06:17 PM
qwikz28's Avatar
Default Mac mids
i need quick help! i just bought a set of mac mids and ory off the classifieds. it was off a 98 ls1 i believe. the guy said it would work with my 02. is this right? or is he mistaken? thanks in advance.
jacob
Old Jul 8, 2005 | 06:23 PM
superchannelkev's Avatar
it will work you just need to block off the egr, if i remember correctly
Old Jul 8, 2005 | 06:31 PM
qwikz28's Avatar
wont that kill power and make it throw codes?
Old Jul 8, 2005 | 07:53 PM
electricz28's Avatar
You should not set codes since your 02 did't come with the AIR tubes.Check Ebay saw a whole set of block off plates and gaskets for about $10.
Good Luck
Old Jul 8, 2005 | 08:24 PM
jrp's Avatar
jrp
SN95 Director
yes they will work, however as stated you'll need an egr block off plate for the egr provision and either get block off plates for the AIR system or purchase 98-99 air tubes.
Old Jul 9, 2005 | 11:12 PM
qwikz28's Avatar
cool. thanks guys. theres no disadvantages to running this setup right?
Old Jul 10, 2005 | 02:26 AM
Go with it and let us know how it turns out.........
Old Jul 10, 2005 | 03:04 AM
Strahley's Avatar
What, MAC mids? They are not a bad header at all. I run them on mine and have had no problems, and the clearance is real nice
Old Jul 10, 2005 | 10:13 AM
there not bad as stated, but LT's make a litle more torque. I still use MACS mids for the ground clearance on a lowered car. There is one trick that alot of MAC users do. Have the the ball collector cut off the headers and go with a 3" collector and have a 3" y-pipe fabricated.
Good Luck
Old Jul 10, 2005 | 07:33 PM
qwikz28's Avatar
Good Luck
thanks for the tip! i might go ahead and do that. any idea where i can get the above stated parts?
also if i can get them fabricated at a place with a dyno, i will get before and after runs for you guys. thanks a bunch
jacob
Old Jul 10, 2005 | 08:47 PM
jacob
Find a good exhaust shop in your area, make sure they have a mandrel bender.
Old Jul 10, 2005 | 11:27 PM
qwikz28's Avatar
i know a couple good shops. i have kooks within a hours drive but i dont know if i should bring a set of macs over there, its kind of a
