just finished side exhaust
Hopefully you'll share more photos in the future if you make any revisions to the setup. I test fitted a set of stock Z28 slash tips against the side of my car, just in front of the rear tires. With my car being so low it would be damn near impossible to safely fab up something. If there was a way to go with side exits with tasteful exhaust tips, and not risk ripping the exhaust off on a speed bump, I'd do it in a heartbeat.
I plan on taking mine back farther...basically directly in front of the rear tires. I want rectangular tips to get more ground clearance than the ovaled pipe you have (plus it keeps with the theme of the stock design
). Mine will also exit under the car a bit more...about 3 inches off the tips in the pics would put it about where I want it...possibly a hair more.Hopefully when I'm done...the lowest point of my exhaust will be right after the driver's side header before it merges at the X pipe. Even there, it should be tucked up against the body (might even oval the pipe there a bit).
Looks good...props on the fab work.
in the future i may cut the exits off at the SFC and then run both at an angle to achieve an exit a few inches back..but as it sits now..theyre staying where they are.
love them or hate them..they shoot flames and make noise.
then i started it up...just because it sounds so insane..im gonna try and get some videos hosted of idle and revving...just no driving...my tires are totally shot from that burnout contest..i actually pulled cords out by hand.
time for some new BFG's
Bet it sounds insane, get a vid up soon, i'd like to hear this set up.
The car looks really good tho.
