Cutouts
Old Jul 11, 2005 | 05:22 PM
150shotWS6's Avatar
Default Cutouts
NOte: For now I have stock headers! Just wondering I have 2 3" cutouts where should I mount them at for best performance.(normal factory setup)
Old Jul 11, 2005 | 08:15 PM
cjels1's Avatar
lol if you have factory exhaust you only need ONE cutout...
weld it before the pipe jumps over the rear axle.
or you can weld TWO in the Y pipe before they merge but will throw codes i believe
Old Jul 12, 2005 | 11:33 AM
00 Trans Ram's Avatar
If you put them before the "Y", you will probably lose a little power - especially at low RPM. It's actually torque that you're losing. It will sound like the car is faster, and it will rev better in your driveway - but you will oe power. I took my y-pipe off for a while with stock exhaust, and lost some low-end grunt.
But, for the past 2 years I've run with no exhaust after the y-pipe. It sounds pretty good (loud, but with little rasp or drone) and you gain a few HP. I loved it!
Old Jul 12, 2005 | 11:53 AM
One Bad Z's Avatar
You lose low end power but gain top end power. I never had mine dynoed so i cant tell you where the curve is.
Not worth it for the money. I have dual elec cutouts now and they are coming off very soon. Subframe connectors wont clear them. If im driving by myself i have to be careful about dragging. If there is one more riding along, extra careful. More than one, my **** is dragging my driveway just sitting there.... Ground clearance sucks.
Old Jul 13, 2005 | 03:11 PM
2_wacko's Avatar
Here is where mine is at.
Old Jul 14, 2005 | 03:16 AM
SLP/Drew's Avatar
what wont clear the cutouts or the subframes...Im looking for a new y-pipe and perhaps electronic cutouts and clearance is a huge issue...Do the cutouts cost you clearence???
Old Jul 14, 2005 | 03:40 AM
One Bad Z's Avatar
Connectors wont clear with the cutouts (not the way i have my cutouts setup).
They will cost you ground clearance.
Like i said, im taking them off my car and doing the exhaust the way i should have from the beginning instead of spending all the money just for the "open headers sound" and always having to watch about dragging.
Old Jul 14, 2005 | 07:04 AM
Texas TransAm's Avatar
That is EXACTLY what I've been looking for. If you don't mind I may steal that pic!
