Hard time starting engine
Old Jul 13, 2005 | 03:18 PM
1BAD99TA's Avatar
Default Hard time starting engine
When I go to start the engine it turns over but does not fire. I have to turn the key let is crank over then turn off the key about 3 times before it starts. What could be doing this????
Old Jul 13, 2005 | 08:14 PM
Grimes's Avatar
Are you getting any security lights? And what was the last mod that you did? With more info we can help!
Old Jul 13, 2005 | 08:22 PM
Full-Force's Avatar
Long cranking times can be a fuel pump on its way out. Maybe something as simple as a fuel filter. Im sure its fuel related.
Old Jul 14, 2005 | 05:20 PM
1BAD99TA's Avatar
I have not done any mods lately. Today it did not want to start in the morning but then in the middle of the day it started fine and this evening it took 5 times to get it started. I am confused!!
Old Jul 14, 2005 | 06:18 PM
Seagraves#85's Avatar
My buddy's car is doing the same exact thing. We put plugs in it, they are all gapped right and it wasnt doing that before. I think it might just be a coincedence but we are gonna change the fuel filter first, and go from there. If you figure out the problem let me know and I'll do the same.
Old Jul 14, 2005 | 10:55 PM
Grimes's Avatar
Check all your grounds and connections to the battery. Fuel filter is a possibility too. How many miles you have, and have you changed it yet?
Old Jul 15, 2005 | 08:53 PM
1BAD99TA's Avatar
Well I put in a new ignition relay and it seemed to fix the problem.
Thanks for all of you help
Old Jul 16, 2005 | 10:27 PM
Hey man thanks, I just did the same to my buddy's car and it fixed his problem as well.
Does anyone have a schematic for the ignition relay circuit?
