annoying ticking... what could it be??
Old Jul 15, 2005 | 08:00 PM
jlashley2001ss's Avatar
Default annoying ticking... what could it be??
after my header install i have this annoying ticking sound.. WTF!! what u guys think it is. i had the exhaust guy check it out and he said there were no leaks. what could it be??
Old Jul 15, 2005 | 08:25 PM
Go Topless's Avatar
What type of tick is it. Is it like an air sound or metal tick? My bet would be on a leak from around the header flange(where it bolts to the head). Not knocking this exhaust guy that checked it, but did he actually check under the hood, or just the collectors underneath and the rest of the system?
Old Jul 15, 2005 | 08:49 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Are the Pacesetters the emissions ones? If so it could be the AIR check valve.
Old Jul 15, 2005 | 10:34 PM
they are the emissions type pacesetters. the exhaust said it was the merge collectors that was making the sound. ive never heard of that but what do i know??????
Old Jul 16, 2005 | 06:47 AM
jay_99z's Avatar
Easiest way I can tell you is to start it up and feel around the header gasket and collector. You shouldn't have much trouble feeling the hot air leaking. It's hard to locate a leak just going by sound.
Old Jul 16, 2005 | 06:31 PM
ArcticZ28's Avatar
my guess is AIR check valve, usually craps out.... block em off
Old Jul 16, 2005 | 06:40 PM
Coy's Avatar
Coy
My car was making that sound when I installed LT's. I went around 2,000 miles with no problems. I deleted !AIR, !EGR and the ticking went away completely.
Old Jul 17, 2005 | 12:09 PM
anybody in NC that will take my AIR system out for me and delete codes hit me up!!
Old Jul 17, 2005 | 01:01 PM
jay_99z's Avatar
Here one for ya. Don't know what she would charge just to delete codes.
https://ls1tech.com/forums/member.php?userid=1872
Removing the AIR system is pretty easy. Blockoff plates and start tearing stuff out.....
Old Jul 18, 2005 | 01:09 AM
ArcticZ28's Avatar
super easy... once you remove the AIR from the headers, just trace back the tubing down to the front driver's side of the car, unbolt the shield from underneath and remove that ****, leave all the wires hanging, then get the codes deleted... simple
Old Jul 18, 2005 | 06:56 AM
i guess i would still pass emissions aslong as i had it tuned right??
Old Jul 18, 2005 | 07:59 AM
ArcticZ28's Avatar
yep, once you get the codes deleted, it's all history
Old Jul 18, 2005 | 08:36 AM
Jake19_2's Avatar
heres the header ticking fix
http://www.ls1camaro.net/sections.ph...ticle&artid=11
Old Jul 18, 2005 | 11:32 AM
Originally Posted by Jake19_2
doing this will cause a SES light correct?
Old Jul 18, 2005 | 02:03 PM
ArcticZ28's Avatar
yep, code delete time
Old Jul 18, 2005 | 05:09 PM
will the air check valve mod (im guessing this is the restrictor plate mod) cause an SES light??
Old Jul 18, 2005 | 08:08 PM
ArcticZ28's Avatar
Most people just use blockoffs, it is easier. One guy posted recently about how the restrictor plate caused audible whistling, which was obviously annoying. That may or may not throw a code due to the modified airflow. Try it out if you want.
Old Jul 18, 2005 | 08:17 PM
well i bought the block off plates from speed inc. so im still debating on whether not just deleting the AIR system or doing the restrictor plates. im thinking i can save money and not get a tune but still like i said im debating. how long u think it would take to take out the AIR system??
